Zombiverter Din_Brake will it trigger BrakeLight D_out
alucas
Has thanked: 4 times
Post by alucas »
I have my brake sensor wired to Din_Brake and my brake lights are on a relay run by the BrakeLight output using SL2Func. When I press the brakes I don't get brake lights.
I think that the BrakeLight is only triggered via regen braking and that is why I don't get bake lights when the car is sitting not in run mode and not regen braking. I just wanted to check that is the case before I go do some funny wiring. I like the relay as it is a combo fuse-relay setup, and my rewiring to have both regen baking and the old braking would bypass the fuse and use the old cars system which has 3 fuses for the whole cars electrical system. :)
Is my assumption about BrakeLight correct?
manny
Has thanked: 58 times
Been thanked: 159 times
Re: Zombiverter Din_Brake will it trigger BrakeLight D_out
Post by manny »
Yes regen only
if (Param::GetInt(Param::potnom) < Param::GetInt(Param::RegenBrakeLight)) {
    // enable Brake Light Ouput
    IOMatrix::GetPin(IOMatrix::BRAKELIGHT)->Set();
  } else {
    IOMatrix::GetPin(IOMatrix::BRAKELIGHT)->Clear();
  • PSA battery (50kWh)
  • Zombie VCU
alucas
Post by alucas »
I ended up modifying the code so that when the bake is pressed the BRAKELIGHT goes on.
Has thanked: 328 times
Been thanked: 847 times
alucas wrote: Tue Apr 07, 2026 4:49 pm I ended up modifying the code so that when the bake is pressed the BRAKELIGHT goes on.
I would strongly suggest you do not rely purely on the zombie to turn your brake lights on and always retain the "OEM" method and parallel the zombie one. If the zombie fails for whatever reason you still have the 12V wiring/relays to fall back on.
modellfan
Has thanked: 20 times
Been thanked: 61 times
Post by modellfan »
Is there any reason , why this regen brake light is not implemented for sdu ?
Who knows, its a completely different code base. also I believe the tesla boards were running low on IO pins so some functions were not included.
allard
Post by allard »
tom91 wrote: Tue Apr 07, 2026 5:12 pm I would strongly suggest you do not rely purely on the zombie to turn your brake lights on and always retain the "OEM" method and parallel the zombie one. If the zombie fails for whatever reason you still have the 12V wiring/relays to fall back on.
I think Tom is right; from a security perspective it is better to leave the OEM wiring. However if you, like me, don't have the wire anymore and it is hard to rewire because it is in an unreachable place, you can consider using this code:
selectedInverter->SetTorque(torquePercent);
  // START Brake light control - activate on regen OR physical brake press
  bool brakeLightOn = false;
  if(Param::GetInt(Param::potnom) < Param::GetInt(Param::RegenBrakeLight))
  // Check for regen braking
  if(torquePercent < Param::GetFloat(Param::RegenBrakeLight))
      brakeLightOn = true;
  // Check for physical brake press using parameter
  if(Param::GetBool(Param::din_brake))
  // Set brake light output
  if(brakeLightOn)
    IOMatrix::GetPinOut(IOMatrix::BRAKELIGHT)->Set();
  } else {
    IOMatrix::GetPinOut(IOMatrix::BRAKELIGHT)->Clear();
  // END Brake light control - activate on regen OR physical brake press
  // speed = ABS(selectedInverter->GetMotorSpeed());//set motor rpm on interface
  // NO ABS allowed on speed as we need to know direction
  speed = selectedInverter->GetMotorSpeed(); // set motor rpm on interface
see also:
https://github.com/daan0308/Stm32-vcu/t ... eak-input_
I think it would not hurt to add this to the code base anyway since it can also work in parallel with the OEM wiring.
Allard
alucas
Post by alucas »
Thanks Allard for the reply
I agree it would be nice to have this added to the code base as it shouldn't have any impact, for those with the old and new HW connected. It would make things easier for you, me and maybe a few others.
