unfortunately all pwm devices seem to be blockedjohu wrote: ↑Sat Feb 21, 2026 4:09 pm Mine is 10m
Ok, now doThat should spawn /sys/class/pwm/pwm-0:0Code: Select all
echo 0 > /sys/class/pwm/pwmchip0/export
if not you need to troubleshoot whichever error message the above command produces
debian@BeagleBone:~/myprogs$ echo 0 > /sys/class/pwm/pwmchip0/export
-bash: echo: write error: Device or resource busy
debian@BeagleBone:~/myprogs$ echo 0 > /sys/class/pwm/pwmchip1/export
debian@BeagleBone:~/myprogs$ echo 0 > /sys/class/pwm/pwmchip2/export
debian@BeagleBone:~/myprogs$ echo 0 > /sys/class/pwm/pwmchip3/export
debian@BeagleBone:~/myprogs$ echo 0 > /sys/class/pwm/pwmchip5/export
debian@BeagleBone:~/myprogs$ echo 0 > /sys/class/pwm/pwmchip7/export
debian@BeagleBone:~/myprogs$ echo 1000000 > /sys/class/pwm/pwm-0:0/period
-bash: /sys/class/pwm/pwm-0:0/period: No such file or directory
debian@BeagleBone:~/myprogs$ cd /sys/class/pwm
debian@BeagleBone:/sys/class/pwm$ ls
pwmchip0 pwmchip1 pwmchip2 pwmchip3 pwmchip5 pwmchip7
the autostart for evsenogui and also cppwm is deactivated, and in the process list I don't see anything what will block the pwm devices
