Nissan Leaf and Zombieverter minimum components need?
Re: Nissan Leaf and Zombieverter minimum components need?
Hello. Need some information about maximum RPM EM57 Engine. I added 2 reductors from rear audi axis, wonna make AWD. But it multiply reduction ratio. Need RPM near 16000 RMP. Anyone run EM57 with 16K RPM? Thx for answer.
- Bratitude
- Has thanked: 246 times
- Been thanked: 469 times
common info thats easily found.
10500rpm, e+ leaf goes to 11330rpm.
Any faster are bearing speeds start to exceed and rotor may start to expand.
Hi i have a board with this missing components. can someone tell me what component to skip on leaf setup.
- Has thanked: 328 times
- Been thanked: 847 times
What else are you going to control? what pins will you use?
Just fit all and not restrict yourself.
I dont have those component and dont know what they are for. i can order later and fit but now i want to test my leaf motor/inverter without some off this components.
- J0hannes
- Has thanked: 21 times
- Been thanked: 182 times
You have on your list parts from modules: power supply, Can3, RS232, LIN bus, Digital outputs and some others.
At least if you don't have any of those power supply related components you listed, you can't use the board at all.
https://github.com/damienmaguire/Stm32- ... ematic.pdf
If it helps, you can look from the scematic yourself, what goes where.
Thanks Johannes that helpedJ0hannes wrote: ↑Wed Mar 11, 2026 7:21 am You have on your list parts from modules: power supply, Can3, RS232, LIN bus, Digital outputs and some others.
