Unlocking the power/torque of Prius gen 3 drive train?
Has thanked: 330 times
Been thanked: 848 times
Re: Unlocking the power/torque of Prius gen 3 drive train?
Ghia66 wrote: Mon Jan 19, 2026 3:44 pm It works! Thanks Tom you are a genius!
As in it drive again. Okay will add this change to my ever growing December update.
It still does not change the speed limit :)
Can you do the following, log the same params as you have now but with the wheels in the air. Car very secure ofcourse as you will be pushing the motor over 7000 rpm.
Ghia66
Has thanked: 766 times
Been thanked: 66 times
Post by Ghia66 »
Thanks Tom.
Ok will do a wheels in the air test.
I am also going to do a road speed test on an open road to be sure, to be sure!
Could you please suggest a parameter change to get some region back?
Cheers Les
Ghia66 wrote: Mon Jan 19, 2026 6:11 pm I have very little/none regen! Lucky I fitted 4 pot Wilwood brakes!
So there maybe a limit somewhere. can you please provide a log a longer one showing regen. Or a graph of potnom showing if it does reach the -15 as per setting.
Ghia66
Post by Ghia66 »
Thanks, will do.
Am having trouble finding out how to record longer logs… I used to before 🙁
Ghia66
Post by Ghia66 »
So went for a short fun drive before getting the wheels in the air for a spin test.
So there is regen happening.
Need to see if Potnom gets to the -15. Looks like your torque gets to 350ish as it lines up with UDC on your plot. So from this it seems okay as potnom -100 to 100 gets scaled to torque -3500 to 3500, or in your case as its flipped the signs flip.
You seem to be getting to -10 to -15 potnom as per your setting. I would bump your value for regenmax, this is for throttle regen and regenBrake for your braking regen. Just double them if you feel its currently way to little.
Ghia66
Post by Ghia66 »
Thanks Tom, will do.
At present doesn’t feel like any regen.
Are these values ok to use to plot for the wheels in the air test run?
Should be okay.
Please plot on the left: Potnom + UDC + IDC
Plot on the right: Speed
Thank you
Ghia66
Post by Ghia66 »
Thanks Tom, will do…just a newbie question how do you plot left and right?
when selecting spot values to plot using the L and R tick box
https://openinverter.org/wiki/File:Spot_values.png
Ghia66
Post by Ghia66 »
Ghia66
Post by Ghia66 »
Well it spins faster in the air!
Used the handbrake to slow it down at the end.
Didn’t adjust regen.
please confirm which value is which so I am not left guessing.
Ghia66
Post by Ghia66 »
Sorry Tom I must of cut off the screen shot.
I selected L UDC, IDC & Potnom and R Speed
Ghia66
Post by Ghia66 »
Ah, this is better!
Ghia66
Post by Ghia66 »
In the interest of the Gen 3 Prius community would it be worthwhile to do the same test run in reverse? ( my reverse… Greg’s drive)
Ghia66
Post by Ghia66 »
Red UCD
blue IDC
orange Speed
purple Potnom
Ghia66 wrote: Wed Jan 21, 2026 1:18 pm In the interest of the Gen 3 Prius community would it be worthwhile to do the same test run in reverse? ( my reverse… Greg’s drive)
Yes please.
Also wierdly here you get no regen. Also this could be related to "revRegen": 0
Ghia66
Post by Ghia66 »
Thanks Tom, will give it a spin in reverse tomorrow.
What do you suggest to change re regen?
params (4) 2.json
(2.14 KiB) Downloaded 8 times
set it to -15 like the maxregen
Ghia66
Post by Ghia66 »
Thanks Tom, will try that after the stationary spin.
Ghia66
Post by Ghia66 »
This is my reverse (Greg’s drive) air spin.
I then changed revregen from off! to on. Left regenmax at -15
The Prius Gen 3 sure likes to rev!
Regen worked well to slow the motor. 🙂
Ghia66
Post by Ghia66 »
marcexec wrote: Sat Nov 22, 2025 3:14 pm Not suggesting to test it on the road, but could the "internal" limit only apply for reverse for some reason?
Probaly even too dangerous with wheels off the ground, though I probably hit 150+ with the motorbike wheel at Dublin Maker when some cheeky kid took it out of reverse :D
Wheels in the air…drive and reverse!
marcexec
Has thanked: 1041 times
Been thanked: 111 times
Post by marcexec »
Ghia66 wrote: Thu Jan 22, 2026 12:06 pm Wheels in the air…drive and reverse!
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
Okay so we can confirm your motor is running in reverse which is fine. Toyota do not limit in reverse it appears.
Both go close to 13K reported.
So there must be a current or power limit you are hitting a certain speed. Question is if its related to requested direction not too sure how to easily plot the driving in reverse and getting the 8K speed.
Id say when you get some time can you get another log and graph doing a run to "top speed" if its safely possible.
Left Potnom + IDC + UDC and right speed. Want to see if we derate potnom based on current limit for example, not sure if we rulled that out before.
