Unlocking the power/torque of Prius gen 3 drive train?
Ghia66
Has thanked: 766 times
Been thanked: 66 times
Re: Unlocking the power/torque of Prius gen 3 drive train?
Post by Ghia66 »
Sorry Tom.
Went yesterday to the shed for a test run but the laptop decided that it wasn’t going to open until Windows 11 installed, so no joy!
Ghia66
Post by Ghia66 »
log (19).csv
(31.6 KiB) Downloaded 22 times
So here is the log and Parameters.
Would love to be able to add some regen to assist the brakes!
params (13).json
(1.96 KiB) Downloaded 29 times
Has thanked: 330 times
Been thanked: 848 times
So your revlim is set to 8000, so yea bump that up for more motor speed.
Off pedal regen can ofcourse be added. try -15 for regenmax https://openinverter.org/wiki/Zombiever ... pot_Values
Also not too sure why your potnom is so low.
Wait you are driving it with dirmode -1, so reverse selected :lol:
Does not affect too much, but you can bump available throttle with "throtmaxRev": 30 -> change this 100 and hold on tight.
If this works then we can add the ability to reverse "forward" for the prius gen3.
Ghia66
Post by Ghia66 »
Thanks again Tom, this is going to be exciting!
Yes, reverse is the new way forward…
Will try these new settings in a few days (am on grandchildren minding duties).
I cannot wait!
Ghia66
Post by Ghia66 »
I went out with my grandson (handling the logging) and we had a very good drive!
Accelerator is much more receptive.
Regen is brilliant!
Didn’t get above 104kph
log (20).csv
(46.56 KiB) Downloaded 36 times
Your 8000 revlim seems to still be present. Is that param increased correctly?
Small note on log, we need idc andnot INVudc :)
Ghia66
Post by Ghia66 »
Thanks Tom, revlim set to 13,000
Sorry was in a rush and didn’t have all of my notes with me!
Look from the data we indeed have reached some sort of Toyota internal Rev limit.
Potnom (throttle) flat and speed stays flat
marcexec
Has thanked: 1044 times
Been thanked: 111 times
Post by marcexec »
Not suggesting to test it on the road, but could the "internal" limit only apply for reverse for some reason?
Probaly even too dangerous with wheels off the ground, though I probably hit 150+ with the motorbike wheel at Dublin Maker when some cheeky kid took it out of reverse :D
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
Ghia66
Post by Ghia66 »
tom91 wrote: Sat Nov 22, 2025 2:24 pm Look from the data we indeed have reached some sort of Toyota internal Rev limit.
Is it similar situation to The Greg Rabbit?
Is there any hope of the Lexus 300 secret sauce knowledge helping?
I will review the prius info some more to figure out where we can make changes.
Ghia66
Post by Ghia66 »
Brilliant, thanks Tom.
I will charge up the battery pack and do some more runs with logs.
Anything that I can do to help?
Ghia66
Post by Ghia66 »
Ghia66 wrote: Sat Mar 08, 2025 3:09 pm Just had to chance my arm with a revlim 13000 run before the teardown!
Just remembered hitting 13,000 rpm unloaded on the bench.
Probably in forward though!
Might be hope for Greg’s Rabbit 🤞
Ghia66
Post by Ghia66 »
Here are the parameters from the last drive
params (16).json
(1.96 KiB) Downloaded 27 times
Battery pack is fully charged
Any changes required before next test drive?
Ghia66
Post by Ghia66 »
Drove the Ghia 18kms from the shed to home in light traffic
and still have 378volts… what fun 😊
Enjoying the regen but noticed that I need to be wary of
snapping quickly off the accelerator as the back of the car wants to
step out of line with rapid deceleration!
log (23).csv
(24.96 KiB) Downloaded 22 times
Ghia66
Post by Ghia66 »
Nice drive to the last Carz and Coffee for the year in Bray.
Here is the log 😊
log (28).csv
(14.07 KiB) Downloaded 17 times
Ghia66
Post by Ghia66 »
Is there anything that can be done (I can do) to get the
Prius to be less juddery when going from reverse to drive and regen brake to drive?
log (30).csv
(7.91 KiB) Downloaded 12 times
log (32).csv
(8.3 KiB) Downloaded 9 times
The logs are not fine enough to see any judder as far as I can see.
Your regen ramp is already at 1. Wait you are on release 2.15A. Please go the latest release first https://github.com/damienmaguire/Stm32- ... /tag/2.30a
Alot of throttle smoothing updates have happened.
Ghia66
Post by Ghia66 »
Thanks Tom
Ghia66
Post by Ghia66 »
Just updated to 2.30A and then uploaded my saved parameters.
Had to then change from ISA shunt to BMW safety.
I noticed that drive is now reverse and reverse is now drive on my gear stick.
Unfortunately the car now doesn’t move… what have I missed?
log (26).csv
(3.97 KiB) Downloaded 9 times
With a direction selected to you see the potnom param increase when plotting it?
You logs indicate that selection a direction generates a torque request. This is strange, did you fully power cycle (12V removed from everything) after the update?
Ghia66
Post by Ghia66 »
tom91 wrote: Mon Dec 29, 2025 12:41 pm You logs indicate that selection a direction generates a torque request. This is strange, did you fully power cycle (12V removed from everything) after the update?
Yes, I removed 12volt and then restarted.
I thought it strange!
Ghia66 wrote: Mon Dec 29, 2025 2:32 pm Yes, I removed 12volt and then restarted.
So even after a 12V power cycle it does not work.
Can you please try a release that is older? like V2.22A or 2.20A It is possible a change I made for the testing Greg was doing in his VW Rabbit causes issues for your setup.
Ghia66
Post by Ghia66 »
tom91 wrote: Mon Dec 29, 2025 3:46 pm So even after a 12V power cycle it does not work.
Thanks Tom, will do. I’ll contact Greg and check what release he is using.
The only odd thing I noticed was that drive is now reverse and reverse is now drive on my gear stick.
