"gain":{
"unit":"mV/dig",
"id":3,
"value":586,
"isparam":true,
"minimum":1,
"maximum":1000,
"default":586,
"category":"BMS",
"i":0
"correction0":{
"unit":"ppm",
"id":14,
"value":-1250,
"isparam":true,
"minimum":-10000,
"maximum":10000,
"default":-1250,
"category":"BMS",
"i":1
"correction1":{
"unit":"ppm",
"id":15,
"value":1500,
"isparam":true,
"minimum":-10000,
"maximum":10000,
"default":1500,
"category":"BMS",
"i":2
"correction15":{
"unit":"ppm",
"id":16,
"value":1000,
"isparam":true,
"minimum":-10000,
"maximum":10000,
"default":1000,
"category":"BMS",
"i":3
"numchan":{
"unit":"",
"id":4,
"value":16,
"isparam":true,
"minimum":1,
"maximum":16,
"default":16,
"category":"BMS",
"i":4
"balmode":{
"unit":"0=Off, 1=Additive, 2=Dissipative, 3=Both",
"id":5,
"value":0,
"isparam":true,
"minimum":0,
"maximum":3,
"default":0,
"category":"BMS",
"i":5
"ubalance":{
"unit":"mV",
"id":30,
"value":4500,
"isparam":true,
"minimum":0,
"maximum":4500,
"default":4500,
"category":"BMS",
"i":6
"idlewait":{
"unit":"s",
"id":12,
"value":60,
"isparam":true,
"minimum":0,
"maximum":100000,
"default":60,
"category":"BMS",
"i":7
"turnoffwait":{
"unit":"s",
"id":58,
"value":72000,
"isparam":true,
"minimum":0,
"maximum":999999,
"default":72000,
"category":"BMS",
"i":8
"idlethresh":{
"unit":"A",
"id":55,
"value":0.5,
"isparam":true,
"minimum":0,
"maximum":10,
"default":0.5,
"category":"BMS",
"i":9
"dischargemax":{
"unit":"A",
"id":32,
"value":200,
"isparam":true,
"minimum":1,
"maximum":2047,
"default":200,
"category":"Battery Characteristics",
"i":10
"nomcap":{
"unit":"Ah",
"id":9,
"value":100,
"isparam":true,
"minimum":0,
"maximum":1000,
"default":100,
"i":11
"icc1":{
"unit":"A",
"id":43,
"value":50,
"isparam":true,
"minimum":1,
"maximum":2000,
"default":50,
"i":12
"icc2":{
"unit":"A",
"id":44,
"value":30,
"isparam":true,
"minimum":1,
"maximum":2000,
"default":30,
"i":13
"icc3":{
"unit":"A",
"id":45,
"value":20,
"isparam":true,
"minimum":1,
"maximum":2000,
"default":20,
"i":14
"icutoff":{
"unit":"A",
"id":57,
"value":2,
"isparam":true,
"minimum":1,
"maximum":200,
"default":2,
"i":15
"ucv1":{
"unit":"mV",
"id":46,
"value":3900,
"isparam":true,
"minimum":3000,
"maximum":4500,
"default":3900,
"i":16
"ucv2":{
"unit":"mV",
"id":47,
"value":4000,
"isparam":true,
"minimum":3000,
"maximum":4500,
"default":4000,
"i":17
"ucellmax":{
"unit":"mV",
"id":29,
"value":4200,
"isparam":true,
"minimum":1000,
"maximum":4500,
"default":4200,
"i":18
"ucellmin":{
"unit":"mV",
"id":28,
"value":3300,
"isparam":true,
"minimum":1000,
"maximum":4500,
"default":3300,
"i":19
"ucellhyst":{
"unit":"mV",
"id":56,
"value":4150,
"isparam":true,
"minimum":1000,
"maximum":4500,
"default":4150,
"i":20
"ucellkp":{
"unit":"",
"id":59,
"value":1,
"isparam":true,
"minimum":0,
"maximum":100,
"default":1,
"i":21
"ucellki":{
"unit":"",
"id":60,
"value":1,
"isparam":true,
"minimum":0,
"maximum":100,
"default":1,
"i":22
"ucell0soc":{
"unit":"mV",
"id":17,
"value":3300,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":3300,
"i":23
"ucell10soc":{
"unit":"mV",
"id":18,
"value":3400,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":3400,
"i":24
"ucell20soc":{
"unit":"mV",
"id":19,
"value":3450,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":3450,
"i":25
"ucell30soc":{
"unit":"mV",
"id":20,
"value":3500,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":3500,
"i":26
"ucell40soc":{
"unit":"mV",
"id":21,
"value":3560,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":3560,
"i":27
"ucell50soc":{
"unit":"mV",
"id":22,
"value":3600,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":3600,
"i":28
"ucell60soc":{
"unit":"mV",
"id":23,
"value":3700,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":3700,
"i":29
"ucell70soc":{
"unit":"mV",
"id":24,
"value":3800,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":3800,
"i":30
"ucell80soc":{
"unit":"mV",
"id":25,
"value":4000,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":4000,
"i":31
"ucell90soc":{
"unit":"mV",
"id":26,
"value":4100,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":4100,
"i":32
"ucell100soc":{
"unit":"mV",
"id":27,
"value":4200,
"isparam":true,
"minimum":2000,
"maximum":4500,
"default":4200,
"i":33
"sohpreset":{
"unit":"%",
"id":53,
"value":100,
"isparam":true,
"minimum":10,
"maximum":100,
"default":100,
"i":34
"idcgain":{
"unit":"dig/A",
"id":6,
"value":10,
"isparam":true,
"minimum":-1000,
"maximum":1000,
"default":10,
"category":"Sensor setup",
"i":35
"idcofs":{
"unit":"dig",
"id":7,
"value":0,
"isparam":true,
"minimum":-4095,
"maximum":4095,
"default":0,
"i":36
"idcmode":{
"unit":"0=Off, 1=AdcSingle, 2=AdcDifferential, 3=IsaCan",
"id":8,
"value":0,
"isparam":true,
"minimum":0,
"maximum":3,
"default":0,
"i":37
"tempsns":{
"unit":"0=None, 1=Chan1, 2=Chan2, 3=Both",
"id":52,
"value":0,
"isparam":true,
"minimum":0,
"maximum":3,
"default":0,
"i":38
"tempres":{
"unit":"Ohm",
"id":50,
"value":10000,
"isparam":true,
"minimum":10,
"maximum":500000,
"default":10000,
"i":39
"tempbeta":{
"unit":"",
"id":51,
"value":3900,
"isparam":true,
"minimum":1,
"maximum":100000,
"default":3900,
"i":40
"pdobase":{
"unit":"",
"id":10,
"value":500,
"isparam":true,
"minimum":0,
"maximum":2047,
"default":500,
"category":"Communication",
"i":41
"sdobase":{
"unit":"",
"id":11,
"value":10,
"isparam":true,
"minimum":0,
"maximum":63,
"default":10,
"i":42
"enable":{
"unit":"0=Off, 1=On",
"id":48,
"value":1,
"isparam":true,
"minimum":0,
"maximum":1,
"default":1,
"category":"Testing",
"i":43
"testchan":{
"unit":"",
"id":49,
"value":-1,
"isparam":true,
"minimum":-1,
"maximum":15,
"default":-1,
"i":44
"testbalance":{
"id":54,
"value":0,
"isparam":true,
"minimum":0,
"maximum":2,
"default":0,
"i":45
"reboot":{
"id":61,
"value":0,
"isparam":true,
"minimum":0,
"maximum":1,
"default":0,
"i":46
"version":{
"unit":"4=0.29.31.B",
"id":2001,
"value":4,
"isparam":false
"hwrev":{
"unit":"0=Unknown, 1=v1.x, 2=v2.0, 3=v2.1, 4=v2.2, 5=v2.3, 6=v2.4",
"id":2104,
"value":3,
"isparam":false
"opmode":{
"unit":"0=Boot, 1=GetAddr, 2=SetAddr, 3=ReqInfo, 4=RecvInfo, 5=Init, 6=SelfTest, 7=Run, 8=Idle, 9=Error, 10=Reboot",
"id":2000,
"value":8,
"isparam":false
"lasterr":{
"unit":"0=NONE, 1=MUXSHORT, 2=BALANCER_FAIL, 3=CELL_POLARITY, 4=CELL_OVERVOLTAGE,",
"id":2101,
"value":0,
"isparam":false
"errinfo":{
"unit":"",
"id":2102,
"value":0,
"isparam":false
"modaddr":{
"unit":"",
"id":2045,
"value":0,
"isparam":false
"modnum":{
"unit":"",
"id":2046,
"value":0,
"isparam":false
"totalcells":{
"unit":"",
"id":2074,
"value":16,
"isparam":false
"counter":{
"unit":"",
"id":2076,
"value":13,
"isparam":false
"uptime":{
"unit":"s",
"id":2103,
"value":494,
"isparam":false
"chargein":{
"unit":"As",
"id":2040,
"value":0,
"isparam":false
"chargeout":{
"unit":"As",
"id":2041,
"value":0,
"isparam":false
"soc":{
"unit":"%",
"id":2071,
"value":0,
"isparam":false
"soh":{
"unit":"%",
"id":2086,
"value":100,
"isparam":false
"chargelim":{
"unit":"A",
"id":2072,
"value":50,
"isparam":false
"dischargelim":{
"unit":"A",
"id":2073,
"value":0,
"isparam":false
"idc":{
"unit":"A",
"id":2042,
"value":0,
"isparam":false
"idcavg":{
"unit":"A",
"id":2043,
"value":0,
"isparam":false
"power":{
"unit":"W",
"id":2075,
"value":0,
"isparam":false
"tempmin":{
"unit":"°C",
"id":2044,
"value":127,
"isparam":false
"tempmax":{
"unit":"°C",
"id":2077,
"value":-40,
"isparam":false
"uavg":{
"unit":"mV",
"id":2002,
"value":3357.21875,
"isparam":false
"umin":{
"unit":"mV",
"id":2003,
"value":0,
"isparam":false
"umax":{
"unit":"mV",
"id":2004,
"value":3847.0625,
"isparam":false
"udelta":{
"unit":"mV",
"id":2005,
"value":3847.0625,
"isparam":false
"utotal":{
"unit":"mV",
"id":2039,
"value":53715.78125,
"isparam":false
"u0":{
"unit":"mV",
"id":2006,
"value":3814.75,
"isparam":false
"u1":{
"unit":"mV",
"id":2007,
"value":3824.6875,
"isparam":false
"u2":{
"unit":"mV",
"id":2008,
"value":1.15625,
"isparam":false
"u3":{
"unit":"mV",
"id":2009,
"value":0,
"isparam":false
"u4":{
"unit":"mV",
"id":2010,
"value":3827.15625,
"isparam":false
"u5":{
"unit":"mV",
"id":2011,
"value":3825.96875,
"isparam":false
"u6":{
"unit":"mV",
"id":2012,
"value":3825.96875,
"isparam":false
"u7":{
"unit":"mV",
"id":2013,
"value":3826.5625,
"isparam":false
"u8":{
"unit":"mV",
"id":2014,
"value":3847.0625,
"isparam":false
"u9":{
"unit":"mV",
"id":2015,
"value":3847.0625,
"isparam":false
"u10":{
"unit":"mV",
"id":2016,
"value":3847.0625,
"isparam":false
"u11":{
"unit":"mV",
"id":2017,
"value":3847.0625,
"isparam":false
"u12":{
"unit":"mV",
"id":2018,
"value":3845.3125,
"isparam":false
"u13":{
"unit":"mV",
"id":2019,
"value":3847.0625,
"isparam":false
"u14":{
"unit":"mV",
"id":2020,
"value":3846.5,
"isparam":false
"u15":{
"unit":"mV",
"id":2021,
"value":3841.53125,
"isparam":false
"uavg0":{
"unit":"mV",
"id":2047,
"value":3357.21875,
"isparam":false
"umin0":{
"unit":"mV",
"id":2048,
"value":0,
"isparam":false
"umax0":{
"unit":"mV",
"id":2049,
"value":3847.0625,
"isparam":false
"tempmin0":{
"unit":"°C",
"id":2078,
"value":127,
"isparam":false
"tempmax0":{
"unit":"°C",
"id":2079,
"value":127,
"isparam":false
"uavg1":{
"unit":"mV",
"id":2050,
"value":0,
"isparam":false
"umin1":{
"unit":"mV",
"id":2051,
"value":0,
"isparam":false
"umax1":{
"unit":"mV",
"id":2052,
"value":0,
"isparam":false
"tempmin1":{
"unit":"°C",
"id":2087,
"value":0,
"isparam":false
"tempmax1":{
"unit":"°C",
"id":2088,
"value":0,
"isparam":false
"uavg2":{
"unit":"mV",
"id":2053,
"value":0,
"isparam":false
"umin2":{
"unit":"mV",
"id":2054,
"value":0,
"isparam":false
"umax2":{
"unit":"mV",
"id":2055,
"value":0,
"isparam":false
"tempmin2":{
"unit":"°C",
"id":2089,
"value":0,
"isparam":false
"tempmax2":{
"unit":"°C",
"id":2090,
"value":0,
"isparam":false
"uavg3":{
"unit":"mV",
"id":2056,
"value":0,
"isparam":false
"umin3":{
"unit":"mV",
"id":2057,
"value":0,
"isparam":false
"umax3":{
"unit":"mV",
"id":2058,
"value":0,
"isparam":false
"tempmin3":{
"unit":"°C",
"id":2091,
"value":0,
"isparam":false
"tempmax3":{
"unit":"°C",
"id":2092,
"value":0,
"isparam":false
"uavg4":{
"unit":"mV",
"id":2059,
"value":0,
"isparam":false
"umin4":{
"unit":"mV",
"id":2060,
"value":0,
"isparam":false
"umax4":{
"unit":"mV",
"id":2061,
"value":0,
"isparam":false
"tempmin4":{
"unit":"°C",
"id":2093,
"value":0,
"isparam":false
"tempmax4":{
"unit":"°C",
"id":2094,
"value":0,
"isparam":false
"uavg5":{
"unit":"mV",
"id":2062,
"value":0,
"isparam":false
"umin5":{
"unit":"mV",
"id":2063,
"value":0,
"isparam":false
"umax5":{
"unit":"mV",
"id":2064,
"value":0,
"isparam":false
"tempmin5":{
"unit":"°C",
"id":2095,
"value":0,
"isparam":false
"tempmax5":{
"unit":"°C",
"id":2096,
"value":0,
"isparam":false
"uavg6":{
"unit":"mV",
"id":2065,
"value":0,
"isparam":false
"umin6":{
"unit":"mV",
"id":2066,
"value":0,
"isparam":false
"umax6":{
"unit":"mV",
"id":2067,
"value":0,
"isparam":false
"tempmin6":{
"unit":"°C",
"id":2097,
"value":0,
"isparam":false
"tempmax6":{
"unit":"°C",
"id":2098,
"value":0,
"isparam":false
"uavg7":{
"unit":"mV",
"id":2068,
"value":0,
"isparam":false
"umin7":{
"unit":"mV",
"id":2069,
"value":0,
"isparam":false
"umax7":{
"unit":"mV",
"id":2070,
"value":0,
"isparam":false
"tempmin7":{
"unit":"°C",
"id":2099,
"value":0,
"isparam":false
"tempmax7":{
"unit":"°C",
"id":2100,
"value":0,
"isparam":false
"u0cmd":{
"unit":"0=None, 1=Discharge, 2=ChargePos, 3=ChargeNeg",
"id":2022,
"value":0,
"isparam":false
"u1cmd":{
"id":2023,
"value":0,
"isparam":false
"u2cmd":{
"id":2024,
"value":0,
"isparam":false
"u3cmd":{
"id":2025,
"value":0,
"isparam":false
"u4cmd":{
"id":2026,
"value":0,
"isparam":false
"u5cmd":{
"id":2027,
"value":0,
"isparam":false
"u6cmd":{
"id":2028,
"value":0,
"isparam":false
"u7cmd":{
"id":2029,
"value":0,
"isparam":false
"u8cmd":{
"id":2030,
"value":0,
"isparam":false
"u9cmd":{
"id":2031,
"value":0,
"isparam":false
"u10cmd":{
"id":2032,
"value":0,
"isparam":false
"u11cmd":{
"id":2033,
"value":0,
"isparam":false
"u12cmd":{
"id":2034,
"value":0,
"isparam":false
"u13cmd":{
"id":2035,
"value":0,
"isparam":false
"u14cmd":{
"id":2036,
"value":0,
"isparam":false
"u15cmd":{
"id":2037,
"value":0,
"isparam":false
"cpuload":{
"unit":"%",
"id":2038,
"value":29.375,
"isparam":false
"serial":{
"unit":"",
"value":"43014017",
"isparam":false
