I picked up a 1991 Sambar that I'm in love with and decided to finally jump into the world of EV swaps after eyeing them for years.
I've sourced a 2018 Leaf stack (gen 3 110kw inverter, 6.6kva charger) and a 2015 40kwh battery.
Phase one is to get the truck up and running. I'll worry about heat and AC later on. I might go electric with the heat, or maybe a small diesel coolant heater. If I go electric, is everything resistive? Or are there some setups that use the AC as a heat pump for heating as well?
Since I want to keep the truck 4x4, I will be using the OEM transmission.
I am unclear on whether it's better to go with a board swap or Zombieverter. Seems like gen 3 Leaf inverters aren't really supported by the board swap yet? Even if they were, what about the PDM/BMS? Looks like the Zombie does everything, but costs a lot more and limits me to what the OEM inverter could do. I'm more worried about turning the power down to preserve the Sambar transmission than I am about turning power up.
Since this is all going in a tiny little truck, it would be very convenient to be able to turn the stack horizontal, so that the inverter is behind the motor instead of on top. Looking at the coolant lines this seems doable, does anyone have experience with this?
