Classic Mini, outlander rdu
- Has thanked: 217 times
- Been thanked: 610 times
Re: Classic Mini, outlander rdu
Doing that many battery locations/boxes is a nightmare for wiring up a BMS to monitor all the cells.
Also leaf cells are not the best.
Best to decide if you care about your rear bench seat or will put your battery box there, it is the easiest place to put it. also the best weight location wise. You could always do the Opto route and put a BMW PHEV pack repackaged in the boot.
It is you first build so best to try and keep thing simple.
- Has thanked: 430 times
- Been thanked: 124 times
I agree with Tom, as a serial over complicator myself I've talked myself out of multiple battery boxes and may well just end up getting an OEM pack and mounting the whole thing. Battery boxes are probably the most complicated part of a conversion and also the highest risk, keeping them simple is key. You can also swap a less than ideal battery pack for something batter in the future, and given the rate of innovation and drive in pack technology it might also prove easier in the future.
thanks tom, would a 530e battery pack be good enough to get me up and running, i guess once its up and running and through dvla i could look at other optionstom91 wrote: ↑Tue Jul 15, 2025 8:14 am Doing that many battery locations/boxes is a nightmare for wiring up a BMS to monitor all the cells.
Yes and for a mini will probably get you about 50-60 miles relatively comfortably.
It was the Opto Mini (My mini) - they failed it on "allegedly" having 6 8mm holes in the floor of the spare wheel well. I didn't get any pre warning or explanation, they just deleted the reg from the DVLA database - no MOT record no Tax record nothing.
I wasnt allowed to see the report or officially be told why it had failed. Eventually the guy on the end of the phone implied what the problem might be.
I told them that there were no holes in the boot floor - i had merely glued the plates and bolt heads in place. It went off to a higher level and eventually (i believe) because they had no evidence of actual holes it was re-inspected. The same insurance assessor came as the first time - he didn't know why he had to inspect again and once again couldn't tell me any of the things he had been told to look at!
Obviously when they inspected the 2nd time there were no holes anywhere in the monocoque - and i mean non at all!
Then i got the logbook back - correctly issued as electric!
- Uppertown
- Has thanked: 137 times
- Been thanked: 34 times
Splitting the battery into 3 adds complication and potential failure points. Do you really need the back seat?? If you're prepared to sacrifice the rear seat you'll have room for a full set of modules which would also simplify the BMS. What year is your bodyshell? pre 76 minis had more (factory) holes in the rear bulkhead etc.
iglad you got it sorted pete, i think its crazy that they won't let you drill and bolt something properly but its fine to glue/bond bits together. like the one i mentioned earlier in the post, someone got pinged for drilling a cable through the battery box yet you can buy a battery box with holes already in. crazyTurbopete wrote: ↑Tue Jul 15, 2025 11:46 am It was the Opto Mini (My mini) - they failed it on "allegedly" having 6 8mm holes in the floor of the spare wheel well. I didn't get any pre warning or explanation, they just deleted the reg from the DVLA database - no MOT record no Tax record nothing.
i have an 89 and a 96 at the minute. thinking of getting an older one thoughUppertown wrote: ↑Tue Jul 15, 2025 12:04 pm Splitting the battery into 3 adds complication and potential failure points. Do you really need the back seat?? If you're prepared to sacrifice the rear seat you'll have room for a full set of modules which would also simplify the BMS. What year is your bodyshell? pre 76 minis had more (factory) holes in the rear bulkhead etc.
so i'm looking at the sp06 bmw 26ah 351v hybrid packs, they are pretty cheap and should get the thing built and running, i only need about 30 mile range to get me to mot garage and i don't want to pile a load of money in when the dvla seem reluctant to pass conversions. if the car is an historic [mot exempt} vehicle does it still need to go for an mot?? or would it just get inspected
No knowledge re: classics but I suspect they'll want an MOT anyway as it makes them feel better re: safety. There's an interesting angle for classics where they can retain their historical status if the engine/drivetrain change is for "environmental" reasons. I presume this is done automatically on their end but I'm not sure.
- ianlighting
- Has thanked: 169 times
- Been thanked: 107 times
I’m right in the middle of this as we speak. I wrote up the process in another thread the other day. You should find it by searching dvla.
But to answer your question - mines a 1974 model, so MOT exempt. Had DVLA inspection, which I passed. But that ‘passs’ is subject to a fresh MOT being done. In my case, I had previously decided to pre-emptively get an MOT pass on record before I started converting. Doesn’t change anything but meant I knew all the nasties were dealt with.
I knew before I started I would go back into the MOT process post conversion, I just wasn’t clear when that annual check would start. Now I know. It’s an essential part of the dvla accepting your conversion.
- ianlighting
The dvla gave me a direct line to the kit and conversions office who wrote to me requesting the fresh mot. Once the mot passes, I call them up and they straighten everything out on the system to make it all ties up as electric.Jacobsmess wrote: ↑Tue Jul 15, 2025 4:28 pm I presume this is done automatically on their end but I'm not sure.
And does it retain its 'classic' status and remain MOT exempt after that?ianlighting wrote: ↑Tue Jul 15, 2025 5:09 pm The dvla gave me a direct line to the kit and conversions office who wrote to me requesting the fresh mot. Once the mot passes, I call them up and they straighten everything out on the system to make it all ties up as electric.
so hopefully it will come back as historic vehicle, electric. i read your post the other day, I think i will do a similar thing, i have a rough mini that i can "practice" onianlighting wrote: ↑Tue Jul 15, 2025 5:09 pm The dvla gave me a direct line to the kit and conversions office who wrote to me requesting the fresh mot. Once the mot passes, I call them up and they straighten everything out on the system to make it all ties up as electric.
- ianlighting
I could speculate, but better that I just report the reality once the process is completed.Jacobsmess wrote: ↑Tue Jul 15, 2025 8:18 pm And does it retain its 'classic' status and remain MOT exempt after that?
