Classic Mini, outlander rdu
- Has thanked: 430 times
- Been thanked: 124 times
Re: Classic Mini (newbie)
Glad you bought the outlander motor I linked. I was getting the desire to buy it and I have no need for it!
i had to, they offered me it for £99, i got all 3 for £225, all 2016 and all grade a so less than 60k, some even come with hv cablesJacobsmess wrote: ↑Sat Jul 05, 2025 8:01 pm Glad you bought the outlander motor I linked. I was getting the desire to buy it and I have no need for it!
so next job is batteries,
is there a post/topic that has battery info with dimensions capacities etc. if not it might be an idea to set one up,
- Has thanked: 385 times
- Been thanked: 1595 times
Here are some https://openinverter.org/wiki/Batteries#OEM_modules
- Has thanked: 217 times
- Been thanked: 609 times
correct tom, i believe can use hi-lo's or coilovers on the suspension as they are replacement aftermarket parts and are fully reversable. i can pretty much do anything with the subframe if i use coilovers, won't need to though with the outlander, basically no cutting drilling or welding to shell. im not sure whether i would get away with removing the front end, replacing the inner wings with brace bars and fitting a grp flip front, this is a common change on classic mini's but it seems to be a bit of a grey area, it would create massive amounts of room cause you could tub the arches and fill the wings with batteries. this may still be possible as there is the radiator cowl on one inner wing and a grille on the other, they would just be tricky to mount without drilling
- Has thanked: 378 times
- Been thanked: 224 times
Getting your EV conversion past the DVLA is stressful enough when you haven't drilled, cut or welded any part of the chassis.PEDR0 wrote: ↑Sun Jul 06, 2025 12:07 am correct tom, i believe can use hi-lo's or coilovers on the suspension as they are replacement aftermarket parts and are fully reversable. i can pretty much do anything with the subframe if i use coilovers, won't need to though with the outlander, basically no cutting drilling or welding to shell. im not sure whether i would get away with removing the front end, replacing the inner wings with brace bars and fitting a grp flip front, this is a common change on classic mini's but it seems to be a bit of a grey area, it would create massive amounts of room cause you could tub the arches and fill the wings with batteries. this may still be possible as there is the radiator cowl on one inner wing and a grille on the other, they would just be tricky to mount without drilling
If you can avoid doing that I would.
Agreed, read this last night, https://www.hagerty.co.uk/articles/main ... assic-car/
Isn’t this ironicPEDR0 wrote: ↑Sun Jul 06, 2025 11:28 am Agreed, read this last night, https://www.hagerty.co.uk/articles/main ... assic-car/
Charger and inverter landed today, collected mock up subframe yesterday along with spare driveshafts (justincaseifuckup) Whats everyone’s thoughts on vcu, acc pedal, anything else i need to get the thing spinning????
Zombieverter for the vcu. You'll need a battery or other power source, contractors (at least 1 but 2 best), a shunt or sbox or something else to control precharge, an accelerator pedal, relay to turn on the inverter from the zombie and a few 12V switches for T15/start etc.
If you look at the wiki there's a few good diagrams for the leaf/lexus/tesla setups, may well be one foe the outlander also.
I would definitely recommend Toms VCU (Citini EVS-VCU) Its proven in 2 builds i have completed with outlander motors and BMW phev battery packs - plus when you compare the price against another VCU that doesn't include the BMS it generally works out very good value.
I was one half of this - It all started very positive however there was a massive shift in the perception of EV's in general in the middle of 2022, along with a big hike in electricity bills - both of which obviously had an impact on the conversion market. In the end the only ones that seem to survive are the ones with either massive financial backing or a distinct lack of conscience!
I just watched your videos.Turbopete wrote: ↑Wed Jul 09, 2025 11:34 am I was one half of this - It all started very positive however there was a massive shift in the perception of EV's in general in the middle of 2022, along with a big hike in electricity bills - both of which obviously had an impact on the conversion market. In the end the only ones that seem to survive are the ones with either massive financial backing or a distinct lack of conscience!
Really sorry this didn't work out for you, apart from the grief for you guys it would have been a great way to keep more Mini's on the road and usable.
i agree, i also enjoyed the build, such a shame as there was a good chance that with the gained knowledge and the help and knowledge on here a more affordable conversion could have been developed, some of the prices for conversions/kits are crazy
any mitsubishi drive shaft experts out there, i was wandering if any other driveshafts fit the pot joints/cups, i searched for the tripod hub and each manufacturer list 6 or seven part numbers.
I’m working on this now - not as a business - just for fun and I’m itching to convert another - I reckon it can be done lots cheaper now.
Re: Classic Mini, outlander rdu
The build begins, I have recieved my motor this morning so I am ready to start fitting it into the subframe, exciting times. I'm still stuck on the controls/vcu side of things, it baffles me at the moment. I am waiting on some arduino kit arrive so I can try to learn how that all works. it will hopefully help further on down the road. I have been looking at batteries but still not made a decision, I think i'll stick with the outlander charger for now but would ideally like fast charging in the future. I like the leaf batteries so far but I think I would have to go for the latest ones to get the capacity. I think it may be possible to put a layer in the floor pan with a false floor as they are only around 70mm deep. I think I could also fit 4 units between the motor and inverter, there seems to be a lot of space left between the bonnet and inverter so could fit something there, I hope I can fit 4 or 6 down the side also, I'll have to have a measure up once the motor is in. I'm also debating whether I should build this into an already historic mini to make the dvla side of things easier.
Any thoughts, ideas, help and info would be much appreciated
- ianlighting
- Has thanked: 169 times
- Been thanked: 107 times
If by ‘latest’ you mean 60 or 62kWh, just be aware that the modules shapes are different to the earlier 24 / 30 / 40kWhs. So not as easy to work with. Also the polarity of the different sizes changes around. There’s a thread I made with dimensions etc somewhere in the Leaf section if it helps.
Dont forget you need to house the batteries in watertight enclosures, they will take up space.
The cables and such will also take up space.
Any welding or drilling done to the mini body will invalidate your V5 if the DVLA check your vehicle. This had happened to @turbopete
also keep in mind you need to achieve at least 72S(300V fully charged) for the outlander voltage range to be happy with the batteries a maximum of 96s (400V charged) is possible.
- Has thanked: 83 times
- Been thanked: 431 times
https://bratindustries.net/product/outl ... -adapters/ is also an option
Thanks for the heads up, i guess the different sized modules will be very helpful in some conversions, looks like the 40kwhs will have to do if i can get enough in. I really want to keep the weight distribution as near to original as possible, this is proving quite tricky with such small spacesianlighting wrote: ↑Mon Jul 14, 2025 12:52 pm If by ‘latest’ you mean 60 or 62kWh, just be aware that the modules shapes are different to the earlier 24 / 30 / 40kWhs. So not as easy to work with. Also the polarity of the different sizes changes around. There’s a thread I made with dimensions etc somewhere in the Leaf section if it helps.
Was that the opto mini, what did they fail it on, did they allow it to be corrected??
That would mean 21 units, there’s potential for for 10/12 in the floor, 6/8 in the front and to keep the weight about right i would need 8 in the boot. This would raise the net weight of the mini by around 120 kgtom91 wrote: ↑Mon Jul 14, 2025 1:14 pm Dont forget you need to house the batteries in watertight enclosures, they will take up space.
