Nissan Leaf Stack not getting revs underload
vitecd
Has thanked: 10 times
Re: Nissan Leaf Stack not getting revs underload
Post by vitecd »
larsrengersen wrote: Mon Jul 14, 2025 12:05 pmSmoothly
It is just my feeling, the car didn't shake
My problems with Verter are : the car shakes, and not getting revs. The original assembly is just for reference, to be clear whether it is software or hardware. If the same setup is going smoothly with Leaf SW, then it is Verter SW or the settings.
Referring to the last logs, Verter is actually getting 6800 revs, but wobbling.
My current question, why Verter can drop the torque request? Why is it not linear?
larsrengersen
Been thanked: 28 times
Post by larsrengersen »
Likely because the Zombiverter is better at trying to protect your cells.
In the Leaf demo you are seeing a serious undervoltage error of 2,7V.
Since the lowest voltage before load was around 3,6V this indicates the pack is really shitty. Allowing the cells to go down that low molests your pack even more.
My suggestion would be: stop abusing this pack before things go wrong and get a better one.
