So you have it running on an ZombieVerter with other components connected?
MLBevo Charger- 11kw & 22kw Info
- Has thanked: 215 times
- Been thanked: 600 times
Re: MLBevo Charger- 11kw & 22kw Info
I will review the code when I get a chance and approve it.
- Has thanked: 43 times
- Been thanked: 10 times
Nice work! I'll set up table test with zombie and connect charger to the battery. I also have pyPLC EVSE for simulating CCS charge if it helps. But I don't have correct charging socket with plug and cover locks, so I need to wait for UDS coding stuff. If you add it inside charger module, just like Foccci ConfigCan function, I could try it even there is no parameter for it.Mitchy wrote: ↑Tue Jul 08, 2025 12:20 am I stripped out all of the UDS stuff for now, Leaving that for the CAN-Bridge...
It should have a pretty good basis for CCS charging; So if you happen to have your system wired up with the DC Bus connections, I'd be interested to see if you can play around with the code to get it to work.
Not that simple. Will require quite a bit of testing to get things running just right. Need the right flow of requests and responses.evMacGyver wrote: ↑Tue Jul 08, 2025 9:26 am If you add it inside charger module, just like Foccci ConfigCan function, I could try it even there is no parameter for it.
Also need to ensure it does not interfere with other parts of Zombie code
Bench tested with the most recent vehicle_testing branch.
I did upload it with the Simulate function still active
Tried to do a online edit once I realized, then a pull request via vscode; somehow got out of sync, so gave up for the night on it.
There's still some improvement to be had, I'm sending more msgs than absolutely required. But it's a good first step to get more testing done.
The PDK shifter and VAG_Utils code is being used in my build; the MQB function is being used for my vehicle CAN spoofing; so both functions of the Utils is proven.
I think you could amend it, you can always get your own Branch to the state you want and do a new request. Then I will close the old one and accept+run checks on the new one.
Then we can merge it into vehicle testing and have others also try it.
It is great progress
