Intrest and Feedback Request Classic EV gauges
Has thanked: 264 times
Been thanked: 717 times
I have a few years back started work on a project to create some EV gauges based a replacement for a "classic Smiths" speedo drive unit.
Just trying to work out if there would be enough intrest to make this a product for purchase. It is designed to work for Mini gauges, Beetle gauges and most other classic Smiths gauges .
The base module would act as the brains and the main speedo and odometer mechanism. This unit can be added to with a "secondary" info screen and rotary encoder with a push button to toggle pages.
At the moment designs are finished for the Mini single big gauge and two smaller clocks.
Mini Centre Gauge during development
Mini twin gauge with final hardware
The classic beetle gauges are not as far along, the Speedo mech just drops in and works.
DVD3500
Has thanked: 71 times
Re: Intrest and Feedback Request Classic EV gauges
Post by DVD3500 »
Ohh ! Very nice! Might be a nice fit for my Triumph Spitfire project!
D@F
Has thanked: 6 times
Post by D@F »
is there a place where i can find the dimenssion to check adaptability on golf mk2 cluster ?
D@F wrote: Fri Apr 18, 2025 9:35 am is there a place where i can find the dimenssion to check adaptability on golf mk2 cluster ?
Please provide the dimensions of the speedo mech in the cluster with pictures.
zippy500
Has thanked: 83 times
Been thanked: 7 times
Post by zippy500 »
I would be interested but along way off yet, my speedo is connected mech to the current gearbox ( 1973 bmw)
zippy500 wrote: Fri Apr 18, 2025 11:14 am my speedo is connected mech to the current gearbox ( 1973 bmw)
What does the BMW speedo and gauge insides look like?
zippy500
Post by zippy500 »
tom91 wrote: Fri Apr 18, 2025 11:56 am What does the BMW speedo and gauge insides look like
Like this one:
https://www.ebay.co.uk/itm/156834626196 ... item&gQT=2
is it doable ?
Anything is do-able, a gauge solution I been working on would probably cost in the region of 300-400 gbp for me to implement for others.
D@F
Post by D@F »
tom91 wrote: Fri Apr 18, 2025 9:40 am Please provide the dimensions of the speedo mech in the cluster with pictures.
i hope this may help :
Depth is also needed.
D@F
Post by D@F »
tom91 wrote: Sun May 04, 2025 7:26 pm Depth is also needed.
if it's needed i can cut, there is plenty of space behind the cluster.
PEDR0
Has thanked: 27 times
Been thanked: 19 times
Post by PEDR0 »
very nice, did you look at the rev counter for the 3 clock setup??
PEDR0 wrote: Wed Jul 09, 2025 9:07 pm rev counter for the 3 clock setup
No i did not should not be difficult to adapt
