Zombieverter + Thunderstruck MCU
CapriV
Has thanked: 39 times
Been thanked: 27 times
Post by CapriV »
I have the zombieverter running my 450h and the battery box contactors.
I have the MCU from Thunderstruck that runs the BMS
Anyone using these two systems combined?
Has thanked: 264 times
Been thanked: 717 times
Re: Zombieverter + Thunderstruck MCU
Do you have a CAN spec for the Thunderstruck MCU?
What functions do you want to have the Zombie do and which the Thunderstruck BMS?
Zieg
Has thanked: 165 times
Been thanked: 159 times
Post by Zieg »
I have the mcu but no Zombie. The manual has pretty decently documented functions and can mappings. It also has a list of OBDii SIDs, and recently Kelan from Thunderstruck sent me a DBC for all the J1939 messages it can handle. If you just want it to pass along SOC, voltage, amps and temps you should be able to do that pretty easily with the j1939 table.
CapriV
Post by CapriV »
tom91 wrote: Tue Apr 15, 2025 9:58 pm Do you have a CAN spec for the Thunderstruck MCU?
Hey.
I want the Zombie to control the 450H with access to the IVT-S can
Then the Thunderstruck MCU to handle the battery charging and management.
I have both setups working separately on the bench.
Kelan said both systems should be able to use the same IVT, I do have 2 of these though.... maybe use one for each?
One thing I have not wrapped my ignorance around yet is how to combine contactor engagement for charging when the zombie is powered down.
I have the Zombie working the negative, positive & precharge contactors using a bench top power supply and the motor is spinning.
I will have 2 separate battery boxes in my car that will be wired in series but how do I get the zombie to close all the contactors (and precharge) for charging via the TS MCU. Or do I wire in a complete second set of contactors for the TS MCU charge circuit only?
I would also need some sort of proximity fail safe wired to the zombie to halt driving when charging.
I'm just getting back to this project from last year so forgive me if this is a dumbo question. . . Thanks
CapriV wrote: Thu Apr 17, 2025 1:18 pm Kelan said both systems should be able to use the same IVT
Zombie configures the IVT different then default so you will need 2.
CapriV wrote: Thu Apr 17, 2025 1:18 pm One thing I have not wrapped my ignorance around yet is how to combine contactor engagement for charging when the zombie is powered down.
Power on the zombie, utilize a 12V input signal to set it to charge mode - possibly need the charge interface set to Chamdemo (or other but can easily be made to work (worst case I code it in)).
As for drive away protection, once in charge mode you cannot go into drive unless you key off the zombie it needs to go through off before allowing drive.
Sharing the Voltage and Current limits can also be done if you have info on the MCU CAN messages.
CapriV
Post by CapriV »
tom91 wrote: Thu Apr 17, 2025 2:04 pm Zombie configures the IVT different then default so you will need 2.
Ok. thanks for the input!
I guess when enabling charge mode it will activate the precharge circuitry?
In does the contactor sequence for charging yes.
Zieg
Post by Zieg »
If you're using the Thunderstruck charger, it has a 12v output that's active during charging. That's how I wake my vcu. Can also be used as a drive inh although it won't be active if charging is finished but the plug is still in.
There's also a NC relay in the charger that opens during charging in case it's helpful to interrupt a signal somewhere.
CapriV
Post by CapriV »
Zieg wrote: Thu Apr 17, 2025 10:46 pm If you're using the Thunderstruck charger, it has a 12v output that's active during charging. That's how I wake my vcu. Can also be used as a drive inh although it won't be active if charging is finished but the plug is still in.
Yes I'm using their TSM2500 Charger (CAN enabled)
Thanks for the help on this, very much appreciated!
Jaybee379
Post by Jaybee379 »
CapriV - how are you progressing with this?
I am planning to use the zombieverter on a Nissan Leaf motor (and I want to use as much of the DCDC and charger bits built in), but I can't easily fit the leaf battery pack (I am converting a tractor to electric, plus I have already used the leaf battery pack).
I am planning on using the Thunderstruck BMS (ideally with LiFePO batteries) - but this means some sort of BMS / VCU integration.
I have an old leaf BMS unit (from a 2011 model), but if I change battery chemistry I will need to "program" the leaf BMS (another challenge!).
The Thunderstruck BMS provides me with a programmable BMS (so I should be able to use LiFePO batteries) - most of the other options seem to focus on Tesla S or X batteries (SimpBMS etc?). Then maybe layer the Tunderstruck MCU on top of their BMS sattelite units, and integrate with the Zombieverter.
Anyway, keen to hear if you made good/any progress (before I start buying the extra kit for my project).
