Brake Pedal over CanBus
Topics relating to the ZombieVerter VCU
medo
Has thanked: 21 times
Post by medo »
Hi, just a quick question, can we receive the brake pedal signal via canbus without laying a new cable to the zombie converter, would have 2 advantages, less cable to reduce the complexity, and would also activate the brake light when regenerating, I think for BMW E6x the canid would be 0x0A8
Has thanked: 330 times
Been thanked: 848 times
Re: Brake Pedal over CanBus
The BMS E6x and E9x have brake over CAN.
At this moment this is not a good idea due to how the CAN reading is done by the Zombie.
No the BMW is NOT setup to turn on brake lights via CAN info from the engine ECU which the Zombie Emulates.
So the short answer is NO & NO.
jetpax
Has thanked: 20 times
Post by jetpax »
tom91 wrote: Thu Mar 06, 2025 10:50 am The BMS E6x and E9x have brake over CAN.
Why is that?
No timeouts or additional plausibility checks carried out.
There would have to be done per device, per variable read and determined through a failure mode analysis what a "correct" response is.
This is something that you cannot just "force" the variable to zero upon a message time out or error.
