Hello all,
I'm a VERY long time lurker but first time poster. Thanks to everyone for making such a beautiful concept a reality (open source use and reuse or existing systems). It is truly magnificent to witness.
Tl;dr: Where can I find the most recent design files, so I can draw them in kicad and submit a pull request?
I recently graduated with my PhD in electrical engineering
and so finally have time to work on all the projects I've collecting, so of course my living room is now a garage. I was about to order the v1c board for the Gen 3 prius inverter (so I can parallel the power stages) on jlcpcb and noticed the -5V voltage inverter was the old version (SG3204) vs the updated LM2776 called out in the readme in Damien's github repo (
https://github.com/damienmaguire/Prius-Gen3-Inverter). Upon finding that, I checked other changes called out in the build log wiki (
https://openinverter.org/wiki/Toyota_Prius_Gen3_Board) (R14 in parallel with C11, for example) weren't reflected in the board or schematic pdfs. I figured I'd make the changes and submit a pull request, but then remembered that Damien draws boards in designspark (vs kicad, but the file extensions are the same/similar).
I went to download designspark and found it's only available for windows
. I'm on Linux and running windows apps has been very hairy for me as of late, so I'd like to redraw the schematic in kicad and draw a new board as well (and submit a pull request). As I've been pouring over the forums, it's a bit hard to keep track of all the small improvements made, so I was wondering if there's a place where the most recent design files live (I went through Johannes' repost as well, but to no avail). Am I missing something fairly obvious to those in the know? I swear I used the search function and watched (almost) all the videos!
Thanks,
DrElectrEkun
