Orion 2 BMS with Thunderstruck 2500 charger
Hello all, new here, but hoping to get some good information. I'm doing an ev build and I've got the equipment listed in the subject. The Thunderstruck would normally interface through the EVCC, with J1772 control through the AVC2 module. It looks like the Orion 2 would take the place of both of these devices. For simplicity, I'd rather just use the Orion by itself. Can anyone verify that this would work before I go down this path?
- Has thanked: 330 times
- Been thanked: 848 times
Re: Orion 2 BMS with Thunderstruck 2500 charger
Are you cross posting from Diy Electric Car? https://www.diyelectriccar.com/threads/ ... id=1131157
The Orion 2 documentation explains what you need to do.
https://www.orionbms.com/charger-integr ... -chargers/
https://www.orionbms.com/manuals/pdf/j1 ... ooting.pdf
