Chademo with Leaf PDM on Zombi VCU
Rustybkts
Has thanked: 17 times
Been thanked: 11 times
Post by Rustybkts »
Can the Zombi VCU control Chademo when the Leaf PDM is enabled which allows the use of the Leaf charger.
As soon as Chademo is selected on "Interface", the HV contactors close unless "Chargemodes" is selected to Ext_Digi.
Normally for Leaf PDM control it is set to Leaf_PDM.
I can use the Orion BMS for Chademo control but will need to trigger the HV contactors and assume that the HV request pin 51 is used to be triggered by the BMS.
Has thanked: 328 times
Been thanked: 847 times
Re: Chademo with Leaf PDM on Zombi VCU
I believe the Nissan PDM as the Chademo gateway is not implemented.
Gen 1 and 2 are in the PDM, Gen 3 is via the VCU.
Rustybkts
Post by Rustybkts »
I have HVreqFunc set to HVrequest but pin 51 doesn't work when connected to 12v high or ground.
Is this inhibited by any other input/setting and is high or low for on.
Okay pin function HVrequest is a dead end in code.
Use DCFCRequest with the Chademo DCFC set, it should enable properly on and off.
Rustybkts
Post by Rustybkts »
DCFCRequest not enabling HV contactors on pin 51 when set.
Tried using DCFCRequest on pin 50 GP12VINFunc but nothing.
I have never used it and have no experience with Chademo on the Zombie, so other will need to chime in.
Setting up my bench test zombie.
Interface: Chademo
Charger: None
Pin Function DCFCRequest on pin 51 Hvrequest
Toggle Charge Mode on and off.
Interface: Chademo
Charger: Leaf PDM
No need for input it goes to AC charging, not good. Will need to review, Chademo needs to be reviewed as the different charger interfaces work slight different.
Chademo is not correctly setup to allow chargers do its own thing right now as its a dedicated DC interfaces and needs another way to do the AC charging.
All this is on the list of things to overhaul and clean up.
Rustybkts
Post by Rustybkts »
Yes I found that selecting Chademo on Interface with Charger set to Leaf PDM brings in the HV immediately as Chademo requires Ext_Digi.
I am not using the Zombi VCU for Chademo so only require the HVRequest input to pull in the HV contactors. The Orion will do the rest with possibly more control than the Zombi VCU offers.
From my perspective, I only require the Leaf PDM AC charging to detect 16A as well as 32A plugs (0x390 byte_5 0x84 and 0x88), HVRequest to pull in the HV contactors and some way of reducing the power drain on the 12v battery supply to the Leaf inverter and PDM as it is almost an amp in total.
Would be happy to beta test any changes.
Rustybkts wrote: Wed Feb 12, 2025 1:45 pm Leaf PDM AC charging to detect 16A as well as 32A plugs (0x390 byte_5 0x84 and 0x88)
Where you find this info or share this testing?
Rustybkts wrote: Wed Feb 12, 2025 1:45 pm power drain on the 12v battery supply to the Leaf inverter and PDM
Sleep is coming with the updated Leaf CAN message generation.
Rustybkts wrote: Wed Feb 12, 2025 1:45 pm HVRequest input to pull in the HV contactors
Will look into this, needs working out properly and not just for your specific situation.
Rustybkts
Post by Rustybkts »
tom91 wrote: Wed Feb 12, 2025 3:41 pm Where you find this info or share this testing?
On an earlier thread last reply viewtopic.php?t=6027
I assume it will also rectify the requirement for a power reset of the VCU after each charge session viewtopic.php?t=6088
Understood but just needs to enable the HV contactor sequence when the Leaf PDM is selected and HVreqFunc is set to HVrequest and pin 51 enabled.
Can you measure the Proximity to ground resistance of the two plugs used to produce this please.
J0hannes
Has thanked: 21 times
Been thanked: 182 times
Post by J0hannes »
Nissan PDM related, do you have PDM pin 9 energized when trying to have DCFC contactors controlled?
It's and additional layer of safety Nissan has implemented
Also, I don't know if this has been noted earlier, but the PDM has a plug in signal for indicator lamp. Pin 10 is pulled down when PDM thinks it has a charging plug. I'll be using this for a dash light as it's in Leaf.
Rustybkts
Post by Rustybkts »
tom91 wrote: Wed Feb 12, 2025 4:52 pm Can you measure the Proximity to ground resistance of the two plugs used to produce this please.
The 32A EVSE lead is 222R and 16A lead is 680R
Rustybkts
Post by Rustybkts »
J0hannes wrote: Thu Feb 13, 2025 8:18 am Nissan PDM related, do you have PDM pin 9 energized when trying to have DCFC contactors controlled?
Will try the charge lamp signal from the PDM as the 106 Electrique dash has one.
My AC charger is working so not sure if I will need the PDM pin 9 utilised.
CHAdeMO will be controlled solely by the Orion as long as I can enable the HV contactor sequence.
GregFordyce
Has thanked: 43 times
Been thanked: 28 times
Post by GregFordyce »
I know this is an old thread but the topic is relevant to my situation. I'm trying to get Chademo working on my van. I'm using a full Leaf stack from a 30kWh AZE0. The wiring is shown below.
Wiring schematic
Wiring schematic
When I try and DCFC the station shows vehicle detected, communication established but fails on the final safety checks. My van goes into charging mode when I power pin 2 and earth pin 10 on the Chademo plug as well as when connecting to the charging station.
I'm not sure about some of my wiring, specifically Pin 2 Chademo -> pin 20 PDM?. Maybe it should be going to pin 22 PDM?
Also pin 7 Chademo currently isn't connected, but the diagram shows it connected to a 12v pullup resistor.
Should I connect it?
What value resistor should I use?
Should the 12v be constant or from the enable relay?
Once I get this working I'll add the info to the wiki.
My params file is below and I'm on 2.30.A
params (3).json
(2.14 KiB) Downloaded 2 times
Peugeot Expert LWB 2009
Zombieverter - Full 80kW Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
GregFordyce
I looked again at how the Leaf PDM is wired to the Chademo socket and changed around PDM pins 20-22 as per this diagram.
Sadly still no charge. I suspect the quick charge contactors aren't closing. Can someone confirm this is how it should be wired and what is required to close the QC contactors in the PDM?
GregFordyce
I confirmed today that the quick charge contactors are not closing when I power pin 2 with 12 volts and earth pin 10.
What is required to close the contactors in the PDM? I suppose I could brute force it by wiring directly to the contactors but I'd rather not.
J0hannes
Post by J0hannes »
GregFordyce wrote: Mon Apr 27, 2026 10:41 am I confirmed today that the quick charge contactors are not closing when I power pin 2 with 12 volts and earth pin 10.
I'm actually starting to look at getting chademo working on my 2017 Leaf stack, so interested to hear if you find a working solution.
Has thanked: 246 times
Been thanked: 469 times
What year pdm?
If you can’t tiger the dcfc contactors externally then you’ll need to hardwire them unfortunately
