Toyota Prius Gen 2 Inverter Controller
Re: Toyota Prius Gen 2 Inverter Controller
You may require slightly different gains thanks to less than identical component layout? (Just guessing) I’d verify with a current clamp.
Also worth graphing position
- Has thanked: 403 times
- Been thanked: 260 times
Don't have a DC clamp meter. Might have a big DC shut and meter around somewhere.
Accuracy of the current doesn't bug me unless it uses that to know how to turn properly. Telling it to turn at zero hertz and it accelerating endlessly, or giving it 1hz and having it clunk slowly does bother me.
Absolutely no idea.What are the specs of your encoder?
From the controller manual (that I'm NOT using, but, might give some insight perhaps?) out of the forklift that the manufacture (who paired it with the motor I'm using, both have their brand on it), sent me. Mostly greek to me. I don't even know what specs an encoder could have:
"2.1.8 SPEED SENSOR INTERFACE
The Speed Sensor Interface converts the quadrature pulse outputs from a speed
encoder to digital speed and direction numbers for use by other drive and system
functions."
"3 Output ENCODER +12_OUT Supply for external motor pulse sensors. Diode in series for B+ protection. Output voltage 11V +-5% at 50mA load.
4 Output ENCODER GND Ground reference for ENCODER, not B+ protected.
5 Input ENCODER CH 1 Phase 1 input from encoder (speed encoder). Internal 1 kΩ pull-up resistor to +12V_OUT
6 Input ENCODER CH 2 Phase 2 input from encoder (speed encoder). Internal 1 kΩ pull-up resistor to +12V_OUT"
3.11.3 SPEED ENCODER SIGNALS
The speed encoder or similar integrated into the motor, provides speed and direction feedback for the Motor Controller. The connector on the Motor Controller side is an AMP Superseal (282088-1). The standard speed encoder produces a two-phase square wave output (Example SKF P/N 6206/VU1028 gives 64 pulses/ revolution per phase). Other pulse rates in the range 32 - 160 p/r can be selected in the Software. (Parameter accessible via CANopen).
32 Item. No. 89Y05120A User’s Guide
1) These two wires [encoder signal] are motor depending. If the motor does not turn (i.e. oscillates around zero speed) at the first start up, these two wires have to be swapped. If the rotation direction is not correct, the SW parameter bit Inverted Rotation Direction in Application Setup Word (2020h:10) shall be set.
Speed encoders are manufactured with a short length of unshielded four conductor cable to which input and output connections are made. Table 4 lists the color-coding and signals names for the standard speed encoder. Figure 17 shows the wiring diagram.
The motor connections (U, V, W) shall never be swapped. The connector on the motor side is an AMP Superseal (282106-1) with integrated RC filter.
To minimize the possibility of electrical noise coupling into encoder lines, avoid routing encoder cables next to conductors carrying high currents or high current pulses. Noise immunity may also be improved by using twisted conductor cable for encoder to drive connections.
Does that say what it is?
I recognize the word "quadrature" with respect to encoders, but it otherwise means nothing to me.
Oh also, I don't know if I have my big motor wires correct (UVW-wise), I just figured if they were wrong it would mean the motor would rotate backwards and I'd have to flip them. Is that no longer true if I'm using an encoder?
I'm not sure that's actually what that's saying, it just quotes one possible encoder as having 64. But, that's a better guess than I have for any other number. If I disassemble the motor am I going to find an encoder with a number on it that I could look up? Or is this built in deeper to the motor and not accessible?
Going through parameters...
respolepairs - Says usually that should be same number of pairs as motor. Mine wasn't, it was left at 1. Should it be 3?
encmode - It seems I have a quadrature encoder without an index, because (I think?) an index pulse needs an extra wire? I only have 4 wires. So that means set to 1.
You could just scope the encoder output and count the number of pulses through 1 revolution, not sure what to set resolver pole pairs to when using an encoder.
Looks like every example I can find of sine parameters sets resolver pole pairs to 1
Finally got around to doing that today.
I'm not sure if it's working perfectly, but, when I tell it to move zero RPM... it now moves zero RPM.
One thing I hadn't seen before I had my encoder hooked up, the inverter actually tries to maintain that when turned on. Before, if the inverter was on and was commanded zero RPM, and I spun the shaft by hand, it freewheeled. Now that it knows the motor position, it gets grouchy and resists turning.
I was still seeing -5 amps when doing nothing on iL2, but then later it went away and not sure why. I guess I'll see if it reappears.
I'm not sure if it's set up correctly yet. When I tell it to turn at 1 RPM, or 3 RPM or whatever, it doesn't seem to match. It's in a very loose ballpark, but not a match.
I told it to graph Angle, manually turned the shaft to zero degrees, and then counted how many cycles I went through for one physical rotation. I figured it would either be accurate at 1:1, or maybe it would be 3:1 because that's how many pole pairs. No, it was about 3.5 or so rotations.
Also, my motor temp says it's -43'C, which, it's not. And, my inverter temp... none of the 6 or 7 options in the dropdown seemed to correspond to reality. Not sure what to pick for that.
Making something resembling progress... I guess.
- Has thanked: 134 times
- Been thanked: 335 times
What you are doing is done with IPM motor with resolver.
If i understand you have ACIM and dual channel encoder. Four wires channel A, B and +12v, gnd.
Inside the brain this is converted to quad encoder position but you need to input how many pulses does single channel make. You count this by putting a LED on signal A and 12V and count it blink.
... If signal is pnp you need to provide gnd to other side of the led...
Correct!
Count... one physical rotation?
And then... do what with that number? Is that my numimp?
LED will blink when encode moves beyont the next step. Here i used 60 slot single channel optical encoder and it worked with ACIM really fine.MattsAwesomeStuff wrote: ↑Sat Mar 23, 2024 7:54 pm Count... one physical location?
https://mazdamx3ev.wordpress.com/2015/0 ... er-senzor/
Yes "numimp" is actually number of impulses on one channel along one rotation. So if you see your encoder stating 64ppr this is 64 pulses per rotation. But inverter sees it as 256 signal for determining speed and direction of rotation because A and B differ in phase. When signal A is 1 B is 0. Thats your AB encoder. Mine was just 60pr without direction data. To do that my inverter switched phase count in software directly. So my motor could simply roll downhill and inverter never knew. Yours could apply a "hil hold" function i guess...
Can you state the P/N for your encoder and some photo of its sticker?
That'd be neat.
It's certainly not grabbing hard. I can move it with my fingers and i had my current set to 90% (on only a 12v battery). But it's non zero.
Hmm, no. The only thing I know about the encoder is that it's a superseal connector that goes into the far side of the motor. I've never fully disassembled the motor or looked at its bottom end. I guess I could try pulling the rotor out or taking off the opposite end plate, but, I basically presume my hands are made of nitroglycerin and I stand a good chance of destroying anything I touch. I just spent 4 weeks ruining a driveshaft (I'll take out these ujoints to re grease them... Oops they're held in place with plastic injection), andCan you state the P/N for your encoder and some photo of its sticker?
a rear diff (sandblasted and painted, oops, pinion bearing seals against driveshaft, not on its own, now diff and bearing are full of sand and water).
Nothing in the spec sheet identifies the encoder other than its pinout.
https://www.dynapar.com/technology/enco ... e_encoder/MattsAwesomeStuff wrote: ↑Mon Mar 25, 2024 8:56 am
Ok, then your best bet would be to put a wheel (a handle) to the shaft and count LED pulses from channel A for one revolution. If there are 64 pulses then so be it, but i am inclined there is more...
That was a great link, it was explained the right way for me to understand.
80.Ok, then your best bet would be to put a wheel (a handle) to the shaft and count LED pulses from channel A for one revolution. If there are 64 pulses then so be it, but i am inclined there is more...
80 pulses per revolution.
I set NumImp to 80 et voila. Zero means zero. A plot of angle shows exactly 1 revolution when I complete one revolution.
I found out what the resolver pole pair parameter does too. It correctly tells the software what 1 revolution is. So if I have 3 pole pairs and tell it to be 3, then 1 hz is actually 1hz instead of 1/3 hz. I'm not sure if that's helpful or not, or immaterial (just a number, whether it's 300% or 100% the speed doesn't matter).
Next up... motor temperature. Or inverter temperature for that matter. I tried every temperature sensor on the drop-down menu, all produced nonsensical temperatures. So, is that something I can create or manually set instead of choosing from the selection?
Just set temperature de rating in software as high as possible, the hardware is smart enough to over temperature derate
Well that's good enough to let it run, but, ideally I could actually find out what the motor and inverter temperatures are. Especially in the initial test drives and such, it's useful information for anything going wrong.
Actual motor temp should never matter unless there's something wrong, it's absurdly overbuilt for the vehicle.
There surely can't be an inability to configure different temperature sensors, right?
mjc506 wrote: ↑Thu Apr 07, 2022 10:35 am The main board itself should only drawn a couple hundred mA (sorry, I forget the exact figure). But the mainboard + inverter + wifi won't be too far from 1.5A (also those LM2965's aren't fantastically efficient, especially dropping from 35V, so 1.8A @12V, or 1.65A @ 13.8V, is probably about right).
Do you hear a quiet high pitched wine from the inverter when you connect 12V? It's only the internal SMPSs running (not the louder noise from PWMs when driving a motor) but is a good sign that all is well.
I'm so glad I found this post because I've been hearing this whine amd I didn't know what It meant.
Please help me get pass this stage because I'm stuck.
I've supplied the inverter with 70v DC for high power and set the fslipspnt to 3 and ampnom to 10 for testing like Damien said on the collab video with Johannes. But nothing is happening, I'm not getting pwm and thus no three phase output to run the motor
Let's back up and make sure we're all on the same page here.
What controller are you using? The one with through-hole components, or the one Johannes built?
It's been a long time since I touched my car, so I'm really fuzzy on the parameters and procedure to get it moving.
No PWM signal at all is a good starting point. Probably faster than me digging up answers would be going through this thread where others troubleshooted the controller for me with the most idiotproof proof-of-life chasing of where it was failing.
I'm using the one Johannes built.MattsAwesomeStuff wrote: ↑Sat Jan 25, 2025 7:17 pm Let's back up and make sure we're all on the same page here.
When I connect everything I can hear the high pitch whine but besides that nothing happens
Alright.
This is (maybe) the wrong thread. This thread is for Damien's through-hole board.
The development thread for Johannes' board is this one: viewtopic.php?t=701
Note that you're not entitled to tech support, though it is nice for other people with the same problems to find them from wherever Johannes might send them.
That said, I suspect your problems are not related to hardware, or the Prius Gen 2 at all, but to basics of the OI firmware itself, your parameters, and your procedure, and those'd likely be identical regardless. So, you'll probably still find most of your answers in this thread, since I had to have people spoonfeed me from the very most basic troubleshooting.
I think the high pitch whine is the internal DC-DC power supply on the Prius controller. If correct that indicates your Prius inverter is being powered up.When I connect everything I can hear the high pitch whine but besides that nothing happens
What procedure are you following for your initial setup? Link me to the instructions you're following and what step you're on and where you're stuck.
If I can re-learn what I have unlearned because I never understood it well in the first place, I can probably blunder through troubleshooting for you.
What diagnostic tools do you have? A variable power supply that'll show you amps and volts? A multimeter or two? An oscilloscope?
[Edited to add: I see you've started a new thread for your own troubleshooting. Sounds good, let's keep it in one place. For archival purposes, conversation is here: viewtopic.php?t=6046 ]
MattsAwesomeStuff wrote: ↑Tue Jan 28, 2025 9:04 pm Alright.
Thank you for taking your time to reply to all my posts.
The reason why I had to comment on other topics was due to a bit of desperation to get this project running.
But I understand and appreciate what you mean when you you say "let keep this in one post for future reference.
