attempting to put together a group buy for this Dilong combo onboard battery charger / DC-DC converter
Brand: Dilong
Part Number: DA8KM22A-400CA-14RCA
the eBayer will accept $500 if we buy 3 or more
Note: I know nothing about these, so please speak up if there are any caveats.
Group Buy: Dilong 6.6kW OBC / 1.5kW DC-DC Converter, 300-550V Output
- Gregski
- Has thanked: 628 times
- Been thanked: 1606 times
- Gregski
Re: Group Buy: Dilong 6.6kW OBC / 1.5kW DC-DC Converter, 300-550V Output
Huh, that's tempting. I think that's the same one posted on the other forum. Any idea how shipping would work?
Edit: And if it doesn't work out for me to get one but you do and need to re-home your Volt dcdc... Let me know. I believe mine is dying.
- Gregski
it appears an outfit in Wilsonville, Oregon, USA called Cascadia Motion sells these and offers some manuals for them, I will try to attach the CAN Bus pdf below
Maybe someone can program this VooDoo into the Zombieverter?
- Etobicoke
- Has thanked: 39 times
- Been thanked: 14 times
I’m also interested in getting one of these chargers so count me in.
I’m just noticing that in the latest Zombieverter release 2.20A in the parameter list https://openinverter.org/wiki/Zombiever ... pot_Values
Under charger types 6=Elcon - Elcon/TC charger protocol via CAN now shows up and from other documentation I understand the Dilong uses ( might use?) the same protocol and CAN so this might be a good start for integration.
Here is the openinverter wiki link:
https://openinverter.org/wiki/Dilong/Cascadia_Chargers
The seller states:
“ These use the same CAN protocol as the Cascadia, Elcon, and TC Chargers, and has a wide level of support, including the AEM VCU, Orion BMS2, and others.
3D CAD files, CAN DBC and full spec sheets are available.”
If anyone has more info on using these with the Zombieverter please chime in as I’m just collecting up the trail of crumbs but it looks worth exploring for a charger dcdc combo unit at a good price.
The seller states:
- Gregski
Gentlemen this is The Last Call for this amazing group buy opportunity, please let me know ASAP if you are interested, strength in numbers and I may ask if the seller will do $450 per unit if we get enough people interested, currently we have 3 potential buyers, please PM me
- Gregski
think outside the box
Initial Impression: nice piece of kit, feels heavy and solid, seems well made.
- Gregski
started a more technical thread on this charger in a more appropriate Batteries and Charging sub forum
I just bought a Dilong aftermarket charger - Now What?
