Toyota GT86 | Gs450h | 8kWh LTO
thomaa
Has thanked: 20 times
Been thanked: 9 times
Post by thomaa »
Hello!! Starting off my build thread at last after a longgg while of reading and studying and asking.
Quick intro:
I'm Thomas. I live in Melbourne, Australia and am studying my undergraduate degree in EE right now.
I have worked on an almost scratch built e-bike project in the past which sorta led me into the world of diy EVs, when i randomly stumbled upon the OI wiki whilst looking for controllers suitable for ebikes.
Given how car-centric this damn city is, its not really viable to get around without a car. I think I'l embrace it with as much sustainability and budget a (broke) uni kid can, and build my own DIY EV!
Many thanks to the community at large for sharing all of your hard work and ingenuity. I hope to contribute something here too!
The plan:
1. I want to convert the GT86, its a very common car here in Melbourne and has always been my dream first car.
2. Will utilise Gs450h drivetrain.
3. 8kWh LTO battery pack, to be tied directly into the Gs450h inverter HV bus as usual. The brand of cells is "TianKang" which I am importing from China with purportedly 93% SoH - the seller says they came out of an electric train which is pretty awesome.
4. Make use of zombieverter for vehicle control.
Thinking:
1. It handles well, is light (1300kg), is RWD and should be very aero and thus have good kms/kWh.
2. The second time I came to the forums was when I found Phillip Schuster's GT86 conversion through his Youtube. It's an awesome conversion, brilliant workmanship. But the one thing that troubled me was how little space the car has, which meant Phillip had to use 4 or 5 seperate battery compartments which seems a huge PITA, and could be unreliable. Finding out about the Gs450h, the choice was obvious, as the engine bay is opened up for a large battery - though to a limit as the weight distribution would probably be horrible if I jammed it full of batteries. Conservative upper limit of 120kg of batteries which is the mass of the engine it would replace.
3. The concept of an unkillable chemistry appealed to me very much - immortal battery pack. Furthermore, in the GT86 chassis it seems impossible to fit a very large amount of battery easily. If the capacity is limited, C-rate must be high enough to support the 200kW Gs450h. I weighed up my options, and LTO seemed to be the safest, most impressive cycle life option. Cons are that they have poor energy density, but the main design criteria I am aiming for is power instead of range. So this isnt a huge problem, at 25C, 8kWh is enough. Which is about 143kg, 70L.
4. de facto for Gs450h. Thanks to all the work done by Damien, johannes, xp677, and more whom I'm not aware of.
Progress so far:
1. So, the project is finally kicking off because I have finally pulled the trigger and bought the car I wish to convert. It's my first car :) It is written off though, and needs some repairs before it can be registered again. Once the conversion is done another certification will be needed before it becomes road legal with the EV modifications. This paper-work seem scary.
2. About July 2024 I sourced a Gs450h tranny and inverter from a nice bloke who is a retired panel beater. He was stripping the car for parts and got it for $1500AUD which seemed very good.
3. These cells were purchased for a mind blowing $500AUD/8kWh. W H A T. They are shipping via sea freight right now, I am incredibly lucky my parents operate a small business in customs & logistics which makes this fairly simple.
4. I assembled my own zombieverter, with board from JLC and some missing chips from digikey. It has been programmed and hooked up to the inverter. After a bit of troubleshooting (it was surprisingly very well behaved), the Gs450h is now spinning! The project is practically done then... right? whats an EV but a big box built around an electric motor.
Future:
An idea for the future with this project (and potentially any Gs450h project, though it makes most sense for my choice of chemistry) is to make use of the boost converter in the Gs450h inverter as a "range-extender". I can make use of a more energy dense chemistry that doesn't necessarily support the same power density as the LTO pack. And recharge the LTO pack at up to 30kW which is plenty for any legal cruising speed. The big challenge here is controlling the boost converter which afaik no one has figured out. Some others have been curious about this, I was heavily dissuaded when Johannes himself said something like "that will be hard, start with something simpler". I haven't been able to put down the idea entirely, so the system should now be modular and work as a 'bog standard gs450h conversion" with the LTO pack only, albeit with very poor range. With opportunity to increase that range.
I plan to share progress updates on youtube, and will use this forum thread as a blog for more details.
https://www.youtube.com/@tamashamas6193
Here are some photos of the things mentioned here
Has thanked: 246 times
Been thanked: 469 times
Re: Toyota GT86 | Gs450h | 8kWh LTO
Welcome :) great project, you will learn lots, and sounds like you have a good understanding of what you are getting into. your plan to just get it running then tackle the boost converter is a good move. Many people never finish because they push for something too complicated. Just get your vehicle driving, then start cleaning things up!
keep us updated with your progress
thomaa
Post by thomaa »
Absoluteeeely will. Thanks for your comments of support!
marcexec
Has thanked: 1044 times
Been thanked: 111 times
Post by marcexec »
Are the 300h available in Australia? Might save you a bit of space and weight, even if it's early days: https://openinverter.org/wiki/Toyota/Lexus_GS300h_CVT
Otherwise very cool concept!
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
Iceman96
Has thanked: 65 times
Been thanked: 19 times
Post by Iceman96 »
Sounds like a great project - good luck and I will follow with interest. I am in the middle of my EV project on a 2006 RA Rodeo upin Brisbane. I originaly wanted to use the GS450h transmission, but gave up after 6 months of looking, as I could not find one for a reasonable price. At $1500 I’d say you got a good deal. I ended up purchasing a stat writeoff 2014 Leaf from Pickles, and am using the running gear from that. I have the full stack installed now, and am currently making some battery boxes that will go under the tray either side ofthe prop shaft. Then I will split the old leaf battery pack up so I can keep the weight down low. Its only a 24kwh pack that is 11 years old with 70% SOH, so it will be used to get the car registered and on the road. Eventually I will upgrade the batteries with an aim of about 200k’s of range. I have been for a few burns around the block already with the leaf pack strapped into the tray, and I am very impressed with the performance. So your 86 should be pretty exciting with the gs450 in it!
thomaa
Post by thomaa »
Iceman96 wrote: Fri Feb 21, 2025 7:20 am Sounds like a great project - good luck and I will follow with interest. I am in the middle of my EV project on a 2006 RA Rodeo upin Brisbane. I originaly wanted to use the GS450h transmission, but gave up after 6 months of looking, as I could not find one for a reasonable price. At $1500 I’d say you got a good deal. I ended up purchasing a stat writeoff 2014 Leaf from Pickles, and am using the running gear from that. I have the full stack installed now, and am currently making some battery boxes that will go under the tray either side ofthe prop shaft. Then I will split the old leaf battery pack up so I can keep the weight down low. Its only a 24kwh pack that is 11 years old with 70% SOH, so it will be used to get the car registered and on the road. Eventually I will upgrade the batteries with an aim of about 200k’s of range. I have been for a few burns around the block already with the leaf pack strapped into the tray, and I am very impressed with the performance. So your 86 should be pretty exciting with the gs450 in it!
Thats awesome! I was keen for leaf to start with too, but couldnt find any good deals in melbourne (best was like 2k) in melbourne over 3 or 4 months of looking. Ratched strapped big battery sounds thrilling...
Hows getting engineer certification work in qld?
thomaa
Post by thomaa »
Update from me:
I've finally gotten the car's title clear of the write-off status!
Necessary to get this done before doing any of the modifications, its much easier to verify the safety and completeness of repairs when the car is still stock. The process was very very arduous and involved a heap of faffing about getting the right paperwork for only very minor damage. This is probably a very niche comment that is relevant to no one on this forum but DO NOT go for the VIV here in Victoria unless you have something real sentimental. But anyways, the repairs are all done!
I was hoping to get started on the EV conversion sooner rather than later but this whole VIV ordeal took much longer than expected, and I had planned to go on a semester exchange program in the coming months so the conversion is going to have to wait till early next year probably :(
Thanks for the interest from everyone though!!
thomaa
Post by thomaa »
Another milestone! And the last few days have been a bit of a roller coaster. The LTO batteries have arrived
[batteries in their natural habitat (a pallet)]
and I've started doing capacity test at the cell level. The cells are testing well-ish, at around 2mOhm, 15Ah. I have a total of 360 cells. The algorithm is basically just
1. discharge pack to 0V
2. disassemble pack
3. charge each cell to 2.75V using trusty aliexpress dc psu, about 2 hours in CC phase @ 6A (hardware limited), then 3 hrs CV phase.
4. test for IR by discharging over 6x 0.1R 50W resistor in parallel and observing voltage drop & current.
They come in modules of 2s10p, and I've only tested 2 modules worth so far, so it is still to be seen if ALL of these cells are in workable condition. I initially had a scare, since the seller sent me a small bundle of 5 cells as a free gift and I tested those ones first... and they tested HORRIBLY - like 4mOhm per cell bad. The rest of the cells in the modules seem to be alright, phew. But not confidence inspiring.
If these cells in the modules are fairly consistent, I'm planning to build a 160s2p pack out of them. The IR is higher than the advertised 1.1mOhm :( so 140kW at the battery is looking like the limit. Still quite speedy for a 200kg pack though.
thomaa
Post by thomaa »
Also, the car is rege'd!
Enjoying driving it around whilst I still can, in all of its infinte gas guzzling, dinosaur burning, planet killing, noisy and stinky glory.
cnstrct
Has thanked: 11 times
Post by cnstrct »
Hey thomaa! Great project.
I have just moved to a 1994 Golf after trying to get the go-ahead for my 2006 Mini Cooper, I talked to a bunch VASS certifying engineers in Melbourne, the last one was the only one that gave me the time of day, he really wanted to to test if a post 1994 passenger car could be converted in AU, and unfortunately he came up short.
The core issue is that there’s no agreed or documented definition of what must be proven to satisfy ADR compliance for a post-1994 conversion, so an approval wouldn’t hold up if it were challenged legally.
I was gutted, but if someone can work through this and find a path it would be awesome for the community, it's frustrating seeing Europe and the US being able to convert post 1994.
Have you spoken to a ceritying engineer?
