Project demystification - make openinverter.org more accessible
Create a thread for each item that needs working on by the community
Has thanked: 266 times
Been thanked: 186 times
Re: Project demystification - make openinverter.org more accessible
Post by jrbe »
Tom, I appreciate all the work you do and don't mean to add to your workload.
When you say you created an index, is this web backend or a visual?
I believe it would help to have a wik creation / editing guide to help others follow the flow of the Wiki. It's great that it's crowd sourced but also chaotic because it's crowd sourced. The current work you're doing might be enough of a template to follow to help avoid the chaos.
Has thanked: 455 times
Been thanked: 1771 times
This already looks good and sounds promising. I've done some of that along the way but not systematically
Has thanked: 264 times
Been thanked: 717 times
jrbe wrote: Fri Dec 20, 2024 2:21 pm When you say you created an index, is this web backend or a visual?
You click the link?
So done the following:
Clean the category usage with the OEM category for example. This should only be used as a "filter" category to get to the OEM you are after or some general comments on the topic.
Also created a Parts category where all sub functions can be housed. This way you can "browse" for info from the OEM or the part function.
My intention would be if you have a page with info on a part and how to use it you ONLY have it linked to the OEM/Manufacturer's category NOT the "OEM" category. Then link it to the function group.
This allows a more dynamic linking of cross function group items, like waterpumps under HVAC and Thermal Management for example.
Has thanked: 222 times
Been thanked: 413 times
Spent the past few days revamping the zombiverter page. Lots of junk, out of date and repetitive sections.
https://openinverter.org/wiki/ZombieVerter_VCU
Broke off some into dedicated pages which will need clean up and work.
Such as the:
leaf-zombie page
Gs450h-zombie page
Openinverter-zombie page
Hardware build
software
programming
Etc
Still a lot of work todo, right now working on the cleaning up fundamental prams and settings
And just a general how-to
Adding in links is needed.
We don’t want to load the main page with too much detailed junk.
Embed videos, pictures, etc greatly appreciated
started a LEAF PDM page, if you have info, please dump https://openinverter.org/wiki/Nissan_leaf_pdm
