ZombieVerter stand by current, seems I need to keep it on trickle charge or is it better to swich it on with ignition ?
on switching it with ignition, I find wifi links OK but only see the menus with no data sometimes?
ZombieVerter stand by current ?
- Has thanked: 330 times
- Been thanked: 848 times
Re: ZombieVerter stand by current ?
Zombieverter is designed to be permantley powered. It draws around +/-150mA on standby
OK thanks,
If I would use a battery disconnect when not in use for a a while, Is there a boot up time before turning the ignition back on?
No there is not particularly long boot up process, you just need to keep in mind that things like an ISAshunt and such need to be running to precharge. So best to give it a few moments before turning ignition on.
