Flexdisk dimensions
steveknox
Has thanked: 16 times
Been thanked: 14 times
Flexdisk dimensions
Post by steveknox »
Does anyone have the dimensions of the gs450h flexdisk?
Or even better does anone have a CAD model of it, or perhaps a known after-market solution for a solid coupler?
I need to make a solid coupler for my application.
Thanks all
Steve
Mazda RX-8
GS450h Running Gear
Outlander Charger
Renault Kangoo 36kwh pack
Has thanked: 207 times
Been thanked: 563 times
Re: Flexdisk dimensions
steveknox wrote: Thu Dec 05, 2024 2:17 pm I need to make a solid coupler for my application.
That is not your problem on your setup. Solve the diff mounting issue and length compensation first.
Has thanked: 215 times
Been thanked: 174 times
Post by jrbe »
Unless everything drivetrain is mounted solidly, without flex, and perfectly straight a solid coupler will be a bad idea.
barracuda816
Has thanked: 45 times
Been thanked: 22 times
Post by barracuda816 »
Really worth listening to the guys above. Having watched the clips you posted, your problem is not the flex coupler. Fix the Diff mount properly and check the alignment and as tom says the length (it does look like there is too much compression on the coupler already, how was it fitting the propshaft, if you had to force or pry in the flange then it is not right) and you will be fine. Fit a solid coupler as it is and you will break something real fast.
steveknox
Post by steveknox »
Thanks all. I'll re-design. Or just give up :/
Mazda RX-8
GS450h Running Gear
Outlander Charger
steveknox
Post by steveknox »
In the interest of completeness for anyone searching for this information and only finding feedback on my personal project, attached are some measurements.
Mazda RX-8
GS450h Running Gear
Outlander Charger
Post by jrbe »
It would be good to verify your measurements on the bolt holes / studs in the yokes. The flex discs can get distorted over time.
You still might struggle to center this unless there's a centering concentric bore.
There are 2 threads for anyone confused. The other has videos that look to show a guibo and a u joint on one short coupling that's allowing the driveshaft to pivot off center and wobble. This solid replacement is to try to eliminate that possibility - my current understanding anyways...
