rrryy39
Posts: 7 Joined: Fri Jul 26, 2024 3:21 pm
Post
by rrryy39 » Tue Nov 26, 2024 4:03 pm
Hi, I am currently using foccci&clara for the EVCC development and I want to be able to let the controller send and receive can frames. RIght now I setup the openinverter-can-tool using pip and I am using pcan. After running the commend
oic can add tx 0x100 AdcProximityPilot 0 16 10
I get this
canopen.sdo.exceptions.SdoCommunicationError: No SDO response received Does this mean that I don't have communication to the board? Thank you in advance
Posts: 6969 Joined: Thu Nov 08, 2018 10:52 pm
Has thanked: 455 times
Been thanked: 1771 times
Post
by johu » Tue Nov 26, 2024 5:13 pm
You need to specify the node id, it defaults to 1 but Clara has 22
Are you writing EVSE code for Clara?
rrryy39
Post
by rrryy39 » Tue Nov 26, 2024 6:44 pm
johu wrote: ↑ Tue Nov 26, 2024 5:13 pm
No, I want to integrate the clara into a vehicle and let the bms control the clara outputs to EVSE. Thank you
davefiddes
Posts: 375 Joined: Mon Jan 18, 2021 12:39 pm
Has thanked: 149 times
Been thanked: 195 times
Post
by davefiddes » Tue Nov 26, 2024 6:55 pm
Glad you got sorted. If you run
the tool will scan the CAN bus looking for any openinverter nodes (well technically anything that responds to CANopen SDO). I find this a useful way to check that all the devices I expect are up and running on the bus.
rrryy39
Post
by rrryy39 » Tue Nov 26, 2024 7:00 pm
davefiddes wrote: ↑ Tue Nov 26, 2024 6:55 pm
Thanks, after the scan, I found Found possible openinverter node: 22. But then I do the commend
oic -n 22 can add tx 0x100 AdcProximityPilot 0 16 10 I got an error
can.interfaces.pcan.pcan.PcanCanInitializationError: A PCAN Channel has not been initialized yet or the initialization process has failed. I made sure there is no other app using the pcan and also restart the labtop. Any hint on how to solve this issue? thank you very much.
davefiddes
Post
by davefiddes » Tue Nov 26, 2024 11:28 pm
That's an odd looking error message. Has the scan stopped working now?
I don't have any experience of using PCAN adapters (on Windows I presume). Have you got a config file setup like the docs describe:
https://python-can.readthedocs.io/en/st ... /pcan.html
If scanning still works can you try a simpler command like "listparams" and/or "dumpall" to check the basic comms are working well.
