About not getting a response using python openinverter-can-tool
rrryy39
Post by rrryy39 »
Hi, I am currently using foccci&clara for the EVCC development and I want to be able to let the controller send and receive can frames. RIght now I setup the openinverter-can-tool using pip and I am using pcan. After running the commend
oic can add tx 0x100 AdcProximityPilot 0 16 10
I get this
canopen.sdo.exceptions.SdoCommunicationError: No SDO response received
Does this mean that I don't have communication to the board? Thank you in advance
Has thanked: 383 times
Been thanked: 1588 times
Re: About not getting a response using python openinverter-can-tool
You need to specify the node id, it defaults to 1 but Clara has 22
oic -n 22 ....
Are you writing EVSE code for Clara?
rrryy39
Post by rrryy39 »
johu wrote: Tue Nov 26, 2024 5:13 pm You need to specify the node id, it defaults to 1 but Clara has 22
oic -n 22 ....
No, I want to integrate the clara into a vehicle and let the bms control the clara outputs to EVSE. Thank you
davefiddes
Has thanked: 79 times
Been thanked: 96 times
Post by davefiddes »
Glad you got sorted. If you run
oic scan
the tool will scan the CAN bus looking for any openinverter nodes (well technically anything that responds to CANopen SDO). I find this a useful way to check that all the devices I expect are up and running on the bus.
rrryy39
Post by rrryy39 »
davefiddes wrote: Tue Nov 26, 2024 6:55 pm Glad you got sorted. If you run
oic scan
Thanks, after the scan, I found Found possible openinverter node: 22. But then I do the commend
oic -n 22 can add tx 0x100 AdcProximityPilot 0 16 10
I got an error
can.interfaces.pcan.pcan.PcanCanInitializationError: A PCAN Channel has not been initialized yet or the initialization process has failed
. I made sure there is no other app using the pcan and also restart the labtop. Any hint on how to solve this issue? thank you very much.
davefiddes
That's an odd looking error message. Has the scan stopped working now?
I don't have any experience of using PCAN adapters (on Windows I presume). Have you got a config file setup like the docs describe: https://python-can.readthedocs.io/en/st ... /pcan.html
If scanning still works can you try a simpler command like "listparams" and/or "dumpall" to check the basic comms are working well.
