zombieverter firmware with working charging (Leaf PDM) Topic is solved
maiks
Has thanked: 7 times
Post by maiks »
Hello,
zombieverter firmware version 2.17A not allowing nissan leaf pdm to charge , i request for github repo with zombieverter firmware that allows pdm to charge .
Thank you
Been thanked: 1914 times
Re: zombieverter firmware with working charging (Leaf PDM)
Please read the forum rules viewtopic.php?t=5714 especially #1
Has thanked: 329 times
Been thanked: 847 times
Details, hello please provide these.
maiks
Post by maiks »
Hello Tom91,
Thank you for your reply.
I’m using a 2015 Nissan Leaf (EM57 motor, inverter, and 3.6kW PDM) along with a Zombieverter running the latest release (2.17A). The motor, inverter, and DC-to-DC converter are all functioning properly. However, I’m encountering an issue when trying to charge the battery.
The PP and CP lines are correctly connected. When I plug in the Type 1 charging cable, the contactors click, and the VCU switches to charge mode. However, when I measure the current going to the battery, it only shows 0.05A, indicating that no power is being delivered by the PDM.
Zieg
Has thanked: 168 times
Been thanked: 160 times
Post by Zieg »
parameters?
maiks
Post by maiks »
Below are screen shots of the parameters of the vcu, incase you need more please let me know
Better than screenshot is this (Download Parameter File):
or the result of http://192.168.4.1/cmd?cmd=json as a text file attachment
maiks wrote: Thu Nov 07, 2024 5:26 pm I’m using a 2015 Nissan Leaf (EM57 motor, inverter, and 3.6kW PDM) along with a Zombieverter running the latest release (2.17A).
Fix is incoming with the next release that is currently undertest. Turned out there was a message missing in charge mode.
maiks
Post by maiks »
here is the full parameters file
params.json
(1.96 KiB) Downloaded 105 times
maiks
Post by maiks »
tom91 wrote: Thu Nov 07, 2024 7:10 pm Fix is incoming with the next release that is currently undertest. Turned out there was a message missing in charge mode.
Thank you!
Do you have any insights on when the next release is expected or what the estimated timeframe might be?
maiks wrote: Thu Nov 07, 2024 7:28 pm Thank you!
All I can say Damien is testing right now.
maiks
Post by maiks »
tom91 wrote: Thu Nov 07, 2024 7:44 pm All I can say Damien is testing right now.
ok lets wait , thanks for the update
Release 2.20A has proven to resolve this issue.
https://github.com/damienmaguire/Stm32- ... /tag/2.20a
maiks
Post by maiks »
tom91 wrote: Thu Dec 05, 2024 10:25 am Release 2.20A has proven to resolve this issue.
Thank you
