The Foccci gallery
Has thanked: 455 times
Been thanked: 1771 times
The Foccci gallery
Thought I'd open up a "build thread" for all Foccci success stories (please no usage questions here)
So from my side
Touran
Picture still shows CHAdeMO adapter, now it is fully integrated. Charge limits calculated by stm32-car MEB BMS module. Max charging power 85 kW
Mathieus Land Cruiser
Charge limits calculated by Orion BMS. Max power 90 kW
Svens Chevy Pickup https://ev-conversions.info/electrified ... et-pickup/
Orion BMS. Max power 82 kW.
uhi22
Has thanked: 231 times
Been thanked: 638 times
Re: The Foccci gallery
Post by uhi22 »
Uwe is charging the laptop with Foccci. The label on the alpitronic charger says "Einfach Schnell Laden", this is "Simply Fast Charging". Fits quite well :-)
celeron55
Has thanked: 38 times
Been thanked: 136 times
Post by celeron55 »
The Omega. 250A (70-80kW) is the most I dare to try with the 13 old 2015 Tesla Model S modules. Only once they've warmed up but not too warm.
dougyip
Has thanked: 9 times
Been thanked: 16 times
Post by dougyip »
Charging at 120kW - which is the maximum output of our station at Mission Raceway near Vancouver, BC. At some point, we will visit a commercial charge station and see if we can charge at 350kW. We're using water cooled Tesla Model 3 modules, so there are no issues with heat. Charge profile is managed by our own controller with an Orion2 BMS also watching in the background for safety.
celeron55
Post by celeron55 »
The Previa, now with Foccci. The pyPLC hardware has been ditched and the connector moved. I've been charging at 180A and under, which is about 50kW. I'll increase that a bit when being at the optimal temperature range (25...45°C), once I have some time.
nathaniel
Been thanked: 54 times
Post by nathaniel »
To add a couple to the gallery, replaced the LIM dit the Foccci controller, after finished the CAN implementation in my VCU project AC charging was working so I wanted to test the DC charging. I have 3 chargers near me and all of them worked perfectly in one try!
Thanks for all the effort you people put into this project!
nathaniel
Post by nathaniel »
Today tried a couple of others, Tesla v2 and a new abb one. Both of them worked directly! No drama, just charging. Very nice. Was one other charger that did not want to charge but it was one without display so no feedback of any kind. Also tried via the qr code also no succes, site was very not responsive. But at this point I don't blame the Foccci for this fail
Has thanked: 89 times
Been thanked: 481 times
Zombie + FOCCCI is a go.
V4 SuC success
geduxaz
Has thanked: 13 times
Post by geduxaz »
First test of Foccci. Works well :)
uhi22
Post by uhi22 »
Charging the wheel chair, 24V lead acid, using industrial switch mode power supply to convert 230V DC to 28V DC. Foccci powered by USB power bank because I killed the planned 24V to USB by shortcut ;-)
Zieg
Has thanked: 165 times
Been thanked: 159 times
Post by Zieg »
Edit: And a big thankyou to everyone who has developed or contributed to the project. I never thought I'd be able to do fast charging on this car. I've still got to sort a few things out but I'm happy that my first attempt was already relatively successful!
LRBen
Has thanked: 86 times
Been thanked: 252 times
Post by LRBen »
Finally drove past a fast charger today and gave it a go. Worked first time! Setup was through the auto config in zombie.
P.S.Mangelsdorf
Has thanked: 290 times
Been thanked: 330 times
Post by P.S.Mangelsdorf »
I finally had a chance to take the '40 to a brand new charging station that's only a few miles from me. This is from the new "Ionna" network, which is funded by a bunch of the major OEMs. They have a FANTASTIC concept, which is building out the EV equivalent of a gas station, primarily by buying rundown gas stations and converting them. So the stations are covered, well lit, with a lounge, bathrooms, and snacks (all accessed via QR code). They have CCS stations on one side of the building, NACS on the other.
The '40 charged flawlessly using FOCCCI.
