(Driving) Tesla SDU in Fiat X19
phillipschip
Has thanked: 4 times
Been thanked: 26 times
Post by phillipschip »
I thought I'd share what I have done so far with my project. I have the motor mounted and am now moving on to the axles.
I am planning on having the Tesla Axles that I have, cut and splined for the Fiat CV outers. The Fiat uses two of the same CV setups for both the inner and outer, so when mounted, the axle has lateral movement (in and out). Seems different from the typical setup with the outer fixed and the inner to allow that type of movement. I guess I just need to measure carefully in the longest position so it isn't too short causing the risk of pulling out the diff end :0
phillipschip
Re: Tesla SDU in Fiat X19
I should probably move this to “projects”
Has thanked: 246 times
Been thanked: 469 times
being rwd, they are doj, double offset joints. a cv on the outer end is not needed as the rear wheels dont do steering.
youll want to measure with the wheel and the driveunit lined up perfectly, full compression of the inner cv races.
phillipschip
Driveshafts arrive today! I got the engine bay painted, now on to the 10 battery modules. Only 9 more to go!
phillipschip
Axles are in.
phillipschip
Interior painted and ready for some wires.
All new brakes and master cylinder done too.
Bleeding brakes in a completely dry brake system was very challenging with this car!
Has thanked: 330 times
Been thanked: 848 times
What angle is the gearbox heat exchanger? The pictures make the angle look quite serveer.
phillipschip
It is slightly tilted forward, but the oil pickup inside the diff is still at the bottom. I might just not be able to drain all old fluid without a pump.
I came to the conclusion that it would be fine: viewtopic.php?p=73331#p73331
phillipschip
Working on the battery boxes. One in the rear somewhere and one in the “frunk”
phillipschip
Got some work done. Decided to redo and go with polycarbonate boxes instead of the aluminum-the metal scared me :0
Almost done with both boxes and contractor box is complete. Each 39/40v module (10 total) will have charging/balancing through its own bms, temperature sensor relays (hooked to fans) and low voltage alarms for individual cell groups.
phillipschip
Question about dc-dc converter. I have + and - wires off of each of my 10 36v modules for charging. I was thinking about just wiring off of these in parallel and using a 36v-12v dc-dc converter for my accessories. Total amp draw with everything on would be less than 10a. Is that a silly idea?
Proton
Has thanked: 227 times
Been thanked: 57 times
Post by Proton »
If they are in series then it would not work. You would short them.
phillipschip
I'm confused as to what would short. Within each battery box I have 5 36v modules in series. I also have a + and - charging wire off of each module. If I just combined all the + and all the - wires in parallel for the converter to draw off the entire pack wouldn't that work?
2fast4u
Has thanked: 8 times
Post by 2fast4u »
I assume you have the modules connected in series to get enough voltage for the drive unit? Do you intend to rearrange the battery packs to a parallell configuration each time you need to use your 12v supply? You cant have the batteries connected in series and parallell at the same time unless your intention is to let the smoke out.
Fiat eBarchetta powered by Leaf
phillipschip
Yes, that makes sense. I could have figured that one out pretty easily had I drawn it out :0 I guess there would be no way to combine the draw of a 36v to 12v dc-dc across the whole pack. It might work to combine every other one in parallel? 3 out of 5? Otherwise, back to looking for an affordable 400v-12v then, or just using a larger 12v battery and charging every time I plug in and charge HV.
Proton
Post by Proton »
If you just want to test you can get something cheap like this one. It an only put out 55W at max.
https://www.aliexpress.us/item/32568050 ... pt=glo2usa
or this one: 750W
https://www.aliexpress.us/item/32568047 ... pt=glo2usa <-------------------
not sure how efficient they are.
phillipschip
I was looking at getting one of these, or one for each battery box-$19 and 240watts on Amazon:
Can't get the link to display
Proton
Post by Proton »
What is the reason you want to have one for each module? it does not make sense.
You need just one 400v to 12v.
phillipschip
Yeah, if I had a 400-12v I'd only use one. I was thinking two if them if I used 36-12v.
phillipschip
They look like this.
My build is kind of a hotrod grocery getter, drag racing as an option deal. I wouldn't be driving more than 20- 30min on a charge (about a 30 mile range) so would be plugged in most of the time. I figured I could use one of these 36-12v dc-dc converters tapped into 3 out of 5 of my modules.
Romale
Has thanked: 346 times
Been thanked: 101 times
Post by Romale »
phillipschip wrote: Tue Nov 05, 2024 1:50 am .... I figured I could use one of these 36-12v dc-dc converters tapped into 3 out of 5 of my modules.
I still can't understand why you don't take a very cheap affordable pdm from Nissan leaf gen 1, opening it you will get 4 contactors and one compact dc/dc for one and a half kW output, gives ideally 14 volts, works from 150 to 420 volts at the input and starts simply by applying +12 to one pin.
evil neodymium :twisted:
Romale
Post by Romale »
phillipschip
That sounds like a good idea. I didn't know about that option. I'll look into that.
phillipschip
What is the weight and price on that Leaf unit? I'm looking for something light and cheap-I have very few accessories that need 12v. My build is kind of a grocery getting electric hotrod weekend at the track type of deal. I didn't have much luck with a brief check on eBay. I searched for "Nissan Leaf first generation pdm".
Romale
Post by Romale »
In Russia, its price is no more than $ 30. I do not know about you. here is the part number to search for and the appearance.
