Hi, I have a CC2 charge port and associated bits from a Hyundia Ioniq AE, part number 91684-G7010.
It has a charge port lock actuator for locking the charging connector in place during DC charging, but I can't figure out how to make it work.
It looks like this:
Reverse, showing the white actuator pin and the white manual release winder:
Looking into the plug socket there are four pins. In the harness I have, top left is orange, top right is yellow, bottom left is blue, bottom right is red:
I have measured resistance across orange and blue of 30 - 40 Ohms as the position of the winder changes but it's very variable and I don't think is intended to be feedback resistance (I've seen the 1K - 11K resistance feedback shown in the LIM forum posts, and it's not that). I don't see any other resistances. I can't find any Ioniq AE wiring schematics either. The actuator part number I think is 91999G7110.
I can't get it to move the pin in any direction, I've tried 12V across orange and blue, where there was a resistance, but nothing ...
EDIT: I must have had a bad connection, I can move the pin in and out using 12V across orange and blue, changing polarity
Question rephrased: any idea what the feedback mechanism should be with this actuator?
Hyundai Ionic AE Charge Port Actuator wiring help needed [SOLVED]
- uhi22
- Has thanked: 245 times
- Been thanked: 684 times
Re: Hyundai Ionic AE Charge Port Actuator wiring help needed
I assume a switch and maybe one or two resistors. Just add an ohm-meter to the two non-motor pins and use your 12V to turn the motor to both ends.
Re: Hyundai Ionic AE Charge Port Actuator wiring help needed [SOLVED]
Yep, you are correct. Once the lock is fully extended we see 1K appear across the feedback wires (red and yellow).
I've written up the part in the wiki here https://openinverter.org/wiki/Hyundai_I ... 1684-G7010.
- uhi22
Triple thumbs up. This is what I call comprehensive documentation. Thank you.
