It's hard to catch the first message with the board powered externally.
Edit. Just barely touched the throttle - motor barely moved - BMS went into error.
15:40:50.491 -> 0
15:40:50.491 -> BMS Status : 2 Drive | Key ON | 84
15:40:50.491 -> Out:1001 Cont:1100 In:1000 Charge Current Limit : 30 A DisCharge Current Limit : 30 A
15:40:50.491 ->
15:40:50.491 ->
15:40:50.491 -> Modules: 14 Cells: 84 Strings: 1 Voltage: 324.411V Avg Cell Voltage: 3.862V Low Cell Voltage: 3.847V High Cell Voltage: 3.866V Delta Voltage: 18mV Avg Temp: 21.097C
15:40:50.491 ->
15:40:50.491 ->
15:40:50.491 -> Module #1 23.16V Cell0: 3.86V Cell1: 3.86V Cell2: 3.86V Cell3: 3.86V Cell4: 3.86V Cell5: 3.85V Neg Term Temp: 22.10C Pos Term Temp: 20.73C
15:40:50.491 -> Module #2 23.17V Cell6: 3.86V Cell7: 3.86V Cell8: 3.86V Cell9: 3.86V Cell10: 3.86V Cell11: 3.86V Neg Term Temp: 20.32C Pos Term Temp: 19.37C
15:40:50.491 -> Module #3 23.17V Cell12: 3.86V Cell13: 3.86V Cell14: 3.86V Cell15: 3.86V Cell16: 3.86V Cell17: 3.86V Neg Term Temp: 19.94C Pos Term Temp: 19.46C
15:40:50.491 -> Module #4 23.17V Cell18: 3.86V Cell19: 3.86V Cell20: 3.86V Cell21: 3.86V Cell22: 3.86V Cell23: 3.86V Neg Term Temp: 20.20C Pos Term Temp: 19.55C
15:40:50.491 -> Module #5 23.18V Cell24: 3.86V Cell25: 3.86V Cell26: 3.86V Cell27: 3.86V Cell28: 3.86V Cell29: 3.86V Neg Term Temp: 21.03C Pos Term Temp: 20.28C
15:40:50.491 -> Module #6 23.18V Cell30: 3.86V Cell31: 3.86V Cell32: 3.86V Cell33: 3.86V Cell34: 3.86V Cell35: 3.86V Neg Term Temp: 23.31C Pos Term Temp: 22.98C
15:40:50.491 -> Module #7 23.17V Cell36: 3.86V Cell37: 3.86V Cell38: 3.86V Cell39: 3.86V Cell40: 3.86V Cell41: 3.86V Neg Term Temp: 21.03C Pos Term Temp: 20.67C
15:40:50.491 -> Module #8 23.17V Cell42: 3.86V Cell43: 3.86V Cell44: 3.86V Cell45: 3.86V Cell46: 3.86V Cell47: 3.86V Neg Term Temp: 21.60C Pos Term Temp: 21.61C
15:40:50.491 -> Module #9 23.16V Cell48: 3.86V Cell49: 3.86V Cell50: 3.86V Cell51: 3.86V Cell52: 3.86V Cell53: 3.86V Neg Term Temp: 23.59C Pos Term Temp: 22.18C
15:40:50.491 -> Module #10 23.17V Cell54: 3.86V Cell55: 3.86V Cell56: 3.86V Cell57: 3.86V Cell58: 3.86V Cell59: 3.86V Neg Term Temp: 21.50C Pos Term Temp: 20.27C
15:40:50.491 -> Module #11 23.17V Cell60: 3.86V Cell61: 3.86V Cell62: 3.86V Cell63: 3.86V Cell64: 3.86V Cell65: 3.86V Neg Term Temp: 22.32C Pos Term Temp: 21.36C
15:40:50.491 -> Module #12 23.19V Cell66: 3.86V Cell67: 3.87V Cell68: 3.87V Cell69: 3.87V Cell70: 3.86V Cell71: 3.86V Neg Term Temp: 21.81C Pos Term Temp: 20.94C
15:40:50.491 -> Module #13 23.18V Cell72: 3.86V Cell73: 3.86V Cell74: 3.86V Cell75: 3.86V Cell76: 3.86V Cell77: 3.86V Neg Term Temp: 20.57C Pos Term Temp: 19.88C
15:40:50.491 -> Module #14 23.18V Cell78: 3.86V Cell79: 3.86V Cell80: 3.86V Cell81: 3.86V Cell82: 3.86V Cell83: 3.86V Neg Term Temp: 21.12C Pos Term Temp: 21.01C
15:40:50.491 -> CANbus 322.14mA 70% SOC 147000.00mAh296.00 | 20000 | 296.00mA 296.08 | 20000 | 296.08mA 296.17 | 20000 | 296.17mA 296.23 | 20000 | 296.23mA 296.32 | 20000 | 296.32mA 294.02 | 20000 | 294.02mA
15:40:50.991 ->
15:40:50.991 -> 0
15:40:50.991 -> BMS Status : 5 Error | Key ON | 84
15:40:50.991 -> Out:1001 Cont:1100 In:1000 Charge Current Limit : 30 A DisCharge Current Limit : 30 A
15:40:50.991 ->
15:40:50.991 ->
15:40:50.991 -> Modules: 14 Cells: 84 Strings: 1 Voltage: 0.000V Avg Cell Voltage: nanV Low Cell Voltage: 5.000V High Cell Voltage: 0.000V Delta Voltage: -5000mV Avg Temp: 0.000C
15:40:50.991 ->
15:40:50.991 -> Module #1 0.00V Cell0: 0.00V Cell1: 0.00V Cell2: 0.00V Cell3: 0.00V Cell4: 0.00V Cell5: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #2 0.00V Cell6: 0.00V Cell7: 0.00V Cell8: 0.00V Cell9: 0.00V Cell10: 0.00V Cell11: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #3 0.00V Cell12: 0.00V Cell13: 0.00V Cell14: 0.00V Cell15: 0.00V Cell16: 0.00V Cell17: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #4 0.00V Cell18: 0.00V Cell19: 0.00V Cell20: 0.00V Cell21: 0.00V Cell22: 0.00V Cell23: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #5 0.00V Cell24: 0.00V Cell25: 0.00V Cell26: 0.00V Cell27: 0.00V Cell28: 0.00V Cell29: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #6 0.00V Cell30: 0.00V Cell31: 0.00V Cell32: 0.00V Cell33: 0.00V Cell34: 0.00V Cell35: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #7 0.00V Cell36: 0.00V Cell37: 0.00V Cell38: 0.00V Cell39: 0.00V Cell40: 0.00V Cell41: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #8 0.00V Cell42: 0.00V Cell43: 0.00V Cell44: 0.00V Cell45: 0.00V Cell46: 0.00V Cell47: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #9 0.00V Cell48: 0.00V Cell49: 0.00V Cell50: 0.00V Cell51: 0.00V Cell52: 0.00V Cell53: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #10 0.00V Cell54: 0.00V Cell55: 0.00V Cell56: 0.00V Cell57: 0.00V Cell58: 0.00V Cell59: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #11 0.00V Cell60: 0.00V Cell61: 0.00V Cell62: 0.00V Cell63: 0.00V Cell64: 0.00V Cell65: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #12 0.00V Cell66: 0.00V Cell67: 0.00V Cell68: 0.00V Cell69: 0.00V Cell70: 0.00V Cell71: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #13 0.00V Cell72: 0.00V Cell73: 0.00V Cell74: 0.00V Cell75: 0.00V Cell76: 0.00V Cell77: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> Module #14 0.00V Cell78: 0.00V Cell79: 0.00V Cell80: 0.00V Cell81: 0.00V Cell82: 0.00V Cell83: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:50.991 -> CANbus 294.02mA 100% SOC 210000.00mAh322.00 | 20000 | 322.00mA 322.01 | 20000 | 322.01mA 321.91 | 20000 | 321.91mA 321.84 | 20000 | 321.84mA 321.75 | 20000 | 321.75mA 320.05 | 20000 | 320.05mA
15:40:51.463 ->
15:40:51.463 -> 0
15:40:51.463 -> BMS Status : 5 Error | Key ON | 84
15:40:51.463 -> Out:0000 Cont:0000 In:1000 Charge Current Limit : 0 A DisCharge Current Limit : 0 A
15:40:51.463 ->
15:40:51.463 ->
15:40:51.463 -> Modules: 14 Cells: 84 Strings: 1 Voltage: 0.000V Avg Cell Voltage: nanV Low Cell Voltage: 5.000V High Cell Voltage: 0.000V Delta Voltage: -5000mV Avg Temp: 0.000C
15:40:51.463 ->
15:40:51.463 -> Module #1 0.00V Cell0: 0.00V Cell1: 0.00V Cell2: 0.00V Cell3: 0.00V Cell4: 0.00V Cell5: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #2 0.00V Cell6: 0.00V Cell7: 0.00V Cell8: 0.00V Cell9: 0.00V Cell10: 0.00V Cell11: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #3 0.00V Cell12: 0.00V Cell13: 0.00V Cell14: 0.00V Cell15: 0.00V Cell16: 0.00V Cell17: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #4 0.00V Cell18: 0.00V Cell19: 0.00V Cell20: 0.00V Cell21: 0.00V Cell22: 0.00V Cell23: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #5 0.00V Cell24: 0.00V Cell25: 0.00V Cell26: 0.00V Cell27: 0.00V Cell28: 0.00V Cell29: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #6 0.00V Cell30: 0.00V Cell31: 0.00V Cell32: 0.00V Cell33: 0.00V Cell34: 0.00V Cell35: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #7 0.00V Cell36: 0.00V Cell37: 0.00V Cell38: 0.00V Cell39: 0.00V Cell40: 0.00V Cell41: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #8 0.00V Cell42: 0.00V Cell43: 0.00V Cell44: 0.00V Cell45: 0.00V Cell46: 0.00V Cell47: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #9 0.00V Cell48: 0.00V Cell49: 0.00V Cell50: 0.00V Cell51: 0.00V Cell52: 0.00V Cell53: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #10 0.00V Cell54: 0.00V Cell55: 0.00V Cell56: 0.00V Cell57: 0.00V Cell58: 0.00V Cell59: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #11 0.00V Cell60: 0.00V Cell61: 0.00V Cell62: 0.00V Cell63: 0.00V Cell64: 0.00V Cell65: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #12 0.00V Cell66: 0.00V Cell67: 0.00V Cell68: 0.00V Cell69: 0.00V Cell70: 0.00V Cell71: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #13 0.00V Cell72: 0.00V Cell73: 0.00V Cell74: 0.00V Cell75: 0.00V Cell76: 0.00V Cell77: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> Module #14 0.00V Cell78: 0.00V Cell79: 0.00V Cell80: 0.00V Cell81: 0.00V Cell82: 0.00V Cell83: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
15:40:51.463 -> CANbus 320.05mA 100% SOC 210000.00mAh295.00 | 20000 | 295.00mA 295.05 | 20000 | 295.05mA 294.58 | 20000 | 294.58mA 293.76 | 20000 | 293.76mA 292.95 | 20000 | 292.95mA 279.11 | 20000 | 279.11mA
15:40:51.964 ->
