CCS controller and inlet is in. Kit at eDubs posted a video before I picked her up.
Next I need to improve the brake pump with the vacuum sensor I got from Citini, then it will be time for an interior.
[DRIVING] 1978 VW T2 Camper
- Been thanked: 9 times
Re: [DRIVING] 1978 VW T2 Camper
New vacuum sensor from Citini (attached to the blue manifold). Works a treat - I am now getting about 7 seconds pump run time every 24 seconds, which may indicate a slight vacuum leak but it will do for now.
- Has thanked: 108 times
- Been thanked: 232 times
Glad to see them in the wild, switches are quite finicky compared to a digital solution.
- ianlighting
- Has thanked: 12 times
- Been thanked: 4 times
Hi DaveH, just scanned through your build posts. I’m at the start of my VW conversion so it’s good to see someone reach the other end!
Can I ask whether it went ok with the dvla in the end? You’ve obviously got a super clean, as new looking vehicle. I’m debating what level of restoration to go for, but I can see it might make the inspector more inclined to pass it if he thinks the vehicle overall is in good shape. Or do you think they have a narrow focus on just the EV bits of the vehicle?
2nd question is are you happy with the brake vacuum pump? Would love to have a link to what you bought if possible. Any changes you’d do if you did it again?
Are you using it regularly now? What’s your range like?
Cheers
Ian
Cheers
Ian
