Zombieverter VCU Connector Female Pins Part Numbers
Has thanked: 633 times
Been thanked: 1610 times
this may help folks find the right pins for the EVBM ZombieVerter VCU if they decide to build their own harness or loose or ruin some in the process, or just need extras, there appear to be two different sizes, and I would recommend the smaller of the two (22-18 AWG) for the synchronous serial wires of the Toyota Prius and the Lexus GS450h (smaller just mean smaller wrap around pieces on the tail end of the pins, the front parts that slip over the male pins are the same size on both)
the links below are for reference only you do not have to buy them from this source, this is just to give you a spring board to jump off of
SICMA 1.5 Female Terminal 16-14AWG (1-2mm2) Part # CONN-101131
SICMA 1.5 Female Terminals, 22-18AWG (0.35 - 0.75mm2) Part # CONN-100857
Re: Zombieverter VCU Connector Female Pins Part Numbers
here is a nice close up from Delphi but they do not mount in this position, what I would call natural horizontal here in the pic, instead they flip on their side and mount vertically, a bit unusual. None of this may make any sense to you until you go to pin one on and then you will have the typical WTH moment.
FI63-211CC2S1160-T.pdf
(210.18 KiB) Downloaded 186 times
this is the header they go on if you are thinking bare bones build
J0hannes
Has thanked: 21 times
Been thanked: 182 times
Post by J0hannes »
There are also terminals separately available from Aliexpress seller referenced in the ZV Wiki:
100 terminals lets you practise crimping for a while ;)
Aliexpress knows these as DJ627-1.5A Punch that in the search bar and you have almost unlimited options to choose from :D
electromatic
Post by electromatic »
Manufacturer part numbers of the pins seem to be 211CC2S2160P for the bigger one and 211CC2S1160P for the smaller one. Reasonably priced on RS.
