Sorry I don't have any links to the wire I used.Can you provide links to the shielded/twisted pair cabling you used for comms and resolver connections? Amazon gives plenty of results, but would be helpful to know what you used and/or recommend.
I "borrowed" some wire from work for my temp setup.
From my experience you don't want to use anything bigger than 20AWG
here are a couple pictures.
the wire on the roll worked well, but it single conductor and non-shielded.
the wire in the box is single pair shield. worked OK, but 20AWG would be better.
Both worked well in the resolver and MOLEX connectors
