- Gregski
- Has thanked: 631 times
- Been thanked: 1607 times
Re: 1984 Voltswagen Rabbit Prius Gen 3 ZOMBIE
and now a lesson on German Electronics from the guy who should not be giving a lesson on anything let alone German Electronics
this is a 2018 BMW 530e hybrid battery pack
why the hell does that say U=
The letter "U", often used to denote voltage supply, is said to be derived from the German word "Unterschied" which means "difference". This loosely implies "voltage difference" which may be used to help understand the meaning of the use of the letter "U" for the power supply to these types of electrical equipment.
- Gregski
Oh, I will...
The "Us" further manifest themselves throughout the Open Inverter web interface software
udcmin - [pronounced: fuel tank is empty] battery pack minimum voltage the VCU will still request torque at
udcmax - [pronounced: stop over squeezing, the gas pump has clicked already and your fuel tank is full] battery pack maximum voltage the VCU will allow the battery to be regened or charged to
udclim - [pronouced: Oh Shit!] the VCU will perform a Hard Shutdown of all systems to prevent badness
- Has thanked: 478 times
- Been thanked: 309 times
I HATE those slide on cage nuts.
Hello ladies and gentlemen, we'd like to design a device that combines the frailty of sheet metal with the frustrations of loose hardware, we introduce... slide on cage nuts. They'll be just like captive nuts, but they'll break and strip all the goddamn time and then cut you when you try to remove them.
Bane of IT server maintainers everywhere, they make their way into automotive use, to share in the misery in a tactic known as "mitigation by dispersal". Every other industry that has to suffer in addition to your own, makes it a little less awful when you have to endure it.
That said, that zombie looks like it was born there. What a fortuitous mounting arrangement. Every build gets one. I think the Zombie saw your tribute to picasso when mounting the inverter and went back in time to tell the Volkswagen engineers to put those bolts there for its own benefit. Couldn't have a more stark contrast between the convenience of the two brackets.
- Gregski
MattsAwesomeStuff wrote: ↑Sun Apr 07, 2024 7:12 pm I HATE those slide on cage nuts.
yes, but how do you really feel?
- muehlpower
- Been thanked: 186 times
The symbol for voltage is U - derived from the Latin urgere (to urge, drive, push). The SI unit is the volt, named after Alessandro Volta.
Alibro
- Has thanked: 505 times
- Been thanked: 324 times
How many times have you been installing a heavy switch or router, struggling for several minutes to screw in a cage bolt only to hear the tinkle as the cage nut decides enough is enough, jumps out of it's mounting hole and drops down the inside of the rack never to be seen again.MattsAwesomeStuff wrote: ↑Sun Apr 07, 2024 7:12 pm I HATE those slide on cage nuts.
- Gregski
you mean as in you told your boss you will move that server to another rack over the weekend outside of production hours but that was before you realized Pete's bachelor party was that Friday and the boys did actually rent an RV [and Vegas is indeed only 10 hours away] and now it's Monday morning and no you are not hung over, that won't start till maybe this evening, your buddies were smart enuff to call in sick, but not you and now you're in the server room at peak login time on Monday morning alone, yes this pizza box 1U does look skinny but who knew it ran all the way down the deepest rack, is rear end heavy loaded up with 3 deep power supplies and cooling fans with square bearings, and maybe you should have unplugged it first or asked Johnson from the SharePointless team to give you a hand but no, you got two screws already in, that should hold it while you go look under the raised floor for some more ... so no, can't relateAlibro wrote: ↑Mon Apr 08, 2024 7:53 am How many times have you been installing a heavy switch or router, struggling for several minutes to screw in a cage bolt only to hear the tinkle as the cage nut decides enough is enough, jumps out of it's mounting hole and drops down the inside of the rack never to be seen again.![]()
- Gregski
P~a~r~t~s
Alibro
So you HAVE been there too!Gregski wrote: ↑Mon Apr 08, 2024 12:49 pm you mean as in you told your boss you will move that server to another rack over the weekend outside of production hours but that was before you realized Pete's bachelor party was that Friday and the boys did actually rent an RV [and Vegas is indeed only 10 hours away] and now it's Monday morning and no you are not hung over, that won't start till maybe this evening, your buddies were smart enuff to call in sick, but not you and now you're in the server room at peak login time on Monday morning alone, yes this pizza box 1U does look skinny but who knew it ran all the way down the deepest rack, is rear end heavy loaded up with 3 deep power supplies and cooling fans with square bearings, and maybe you should have unplugged it first or asked Johnson from the SharePointless team to give you a hand but no, you got two screws already in, that should hold it while you go look under the raised floor for some more ... so no, can't relate
- Gregski
VW MK1 Rabbit Electric Throttle Install
- Gregski
first we tried a 2010 Toyota Prius pedal to keep it in the family
because of the wiggliness in the Rabbit firewall I had to make a block for an offset
nice thing about metal is that you can weld up the holes you don't want
- Gregski
and then I decided to go with one that [ahem] fit, as in 2010 Honda Fit
The first part of this video is solid gold. I hadn't considered that you didn't just pick a bunch of pedals, you chose ones that were all different. Maybe even on purpose!
I'm going to try to get around to adding that info to the wiki somewhere, I think a lot of people could benefit from it.
- Gregski
[rant]
last time my new leather gloves fell apart I knew something was off, I could have sworn I just bought them, so this time, I wrote the Born On Date on the new pair and check this out, they fell apart only one week later, or am I just working too hard and they can't keep up with my Chuck Norris like pace? what are your thoughts on parts and materials in current times ?
4-1-24 (that's Freedom format, so April 1st, 2024)
[/rant]
[/rant]
Alibro
Time to get the needle and thread out.Gregski wrote: ↑Wed Apr 10, 2024 3:30 pm [rant]
[/rant]
- Gregski
ha ha, right? more like HARDLY !
- Gregski
never too early to plan your next battery pack upgrade
so if we were to go to the 6 modules from the BMW 530e which would be 12 killer whales instead of the current 7 (provide we get one from July 2019 and up) this vertical formation would not fit behind the rear seat horizontal frame rail
- Gregski
but if we were to fandangle them sideways like so, they fit with room to spare, and whom ever cut this current hole out got it almost nearly perfect [clairvoyant he is]
- Gregski
while I'm literally waiting on the paint to dry I decided to have at the Zombie controlling the BMW Safety Box
things weren't working, so T-Bone my trusty assistant, suggested we plug more skinny wires into the Zombie
and that did the trick
- Gregski
ZombieVerter VCU BMW Safety Box Control Part II
- Gregski
ZombieVerter VCU - Permanent Power Connection
This is the minimum wiring required to access the Zombie via it's Web Interface. Requires two pins. The Zombie is always "on" maybe a better term would be enabled, this is required to detect charge mode and facilitate timers.
Pin #55 - negative / ground
Pin #56 - positive / 12 volts (fuse recommended)
- Gregski
ZombieVerter VCU - Ignition Connection
In addition to the two wires above, we need a third wire, this wire when disconnected turns the Zombie OFF. However when connected it does NOT change the mode at all, for that to change see Start Connection below.
Pin #15 - positive / 12 volts (fuse recommended)
- Gregski
ZombieVerter VCU - Start Connection
In addition to the three wires above a fourth wire is needed to put the Zombie in RUN mode. This requires a momentary switch, think of turning the key in the ignition switch to the Start position and have it automatically spring back after the starter starts the engine.
Pin #52 - positive / 12 volts (fuse recommended) momentary only
- Gregski
ZombieVerter VCU - CAN1 Connection
The Zombie supports three different CAN channels, this is the first one. It requires two wires one for CAN High signal and a second for CAN Low signal. Usually this two wire pair is twisted together aka a twisted pair. This requires two pins.
Pin #27 - CAN Low will run from the Zombie to some CAN device (Charger, Safety Box, etc.)
Pin #28 - CAN High will run from the Zombie to some CAN device (Charger, Safety Box, etc.)
