After reading a lot on this forum (thanks for all the information!) and looking at other projects to find solutions for my problems, I thought lets also document my EV conversion project/build on this forum.
Car:
Citroen CX 25 GTi 1986
Paintwork not very nice, but technical ok. Has been stored for 5 years, and now I thought lets make it electric. Goal:
Daily driver, range >200km
Assemble the project in a 5,5x2,5m garage box (limited space, no mains power)
I can't weld, I don't have a welder or even electricity so I design the parts to be created without welding, or if not possible to weld somewhere else.
No cutting or welding to the car, I want it to be a bolt in conversion. So when the CX is rusted away, I can put it into another CX
Motor:
Tesla (front) SDU from a 2016 Model X with the Openinverter logic board
The motor works, I have been able to start it up and rev it up.
I have drawn an adapter-frame to connect the SDU to the original CX motor mounts. This is being assembled (welded) by someone now.
The easiest way was to use the original gearbox, and stick some kind of motor to that (There is a CX converted this way), but I wanted a single speed drive, because that’s the beauty of electric motors they don’t need a gearbox. I am using the front SDU because of the limited space within the large subframe of the CX (the rear SDU has a motor mount where de CX steering rack is located).
The SDU is running in reverse (180 deg rotated), so I had to convert the oil pump (as other people documented on this forum). I also rotated the pomp 180 degrees to be able to fit the hoses. I don't know of this will last, otherwise I will fit a external electric oil pump...
For now waiting on the adapter frame, and then sort out the driveshafts. Battery:
8 Modules from a ID.3 (MEB) 12s2p, I don't know the health of the battery, it was a bit of a gamble but the price was quite low...
They are 6,8kWh each, so total 54kWh. I think this will get me >200km of range.
I will make 2 battery boxes, one in front of the motor, and one where the fuel tank was located. The rear box has been drawn, It is not the final version, but I will be something like this with a central custom cooling plate. The front one I will design when the motor is in. BMS:
I will use the EVS BMS system, with the original VW CMU. For the current sensor I will used the IVT current sensor
Not yet started on this, but I think the hardware will be straight forward (almost plug and play)
Charging:
Not yet decided, but no DC fast charge (may be later), so I think a ~10kW AC onboard charger
Hydraulics:
Because it is a large Citroen there are hydraulics! The suspensions is Hydropneumatic (actually I converted my CX once to "Hydractive" suspension) with height control, the breaks are hydraulic powered (so no vacuum pump needed) and also the steering is fully hydraulic (a kind of steer-by-wire "Diravi"). So all this need the be supplied with hydraulic pressure and flow. For this I Bought a 12V motor with pump connected (it needs approx. 180bars ). Because the pomp is now electric, the original pressure regulator is obsolete. (the new pump has a built in max pressure limiter). so with al pressure sensor and I can control the pump via a microcontroller. For the steering (which is speed sensitive) I think I will used an electric motor to replace the original gearbox speed-cable.
Dashboard:
I don't know yet, maybe remove the original dials and use a LCD the create a virtual dashboard
Approval:
Can’t find a lot of information about Dutch approval, but as far as I know if you car is build before 1997 then the will only check if the conversion is according to the rules. The rest of the car will be inspected as a normal MOT (APK).
So for now it is waiting on parts (motor frame), and in the meantime designing battery boxes.
Kind Regards,
