SDU: No udc voltage
Lood
Has thanked: 6 times
Been thanked: 29 times
SDU: No udc voltage
Post by Lood »
I am using a (front) SDU, I have had the drive unit working with 48V. Now I supplied 186V, the precharge contactor closes (udcsw=175V) but after five seconds it opens again. Error code "PRECHARGE". The inverter isn’t reading any voltage (udc around 2V). I measure 186V on the cables going to the inverter. I don’t understand why udc is not reading any voltage?
why there is no udc voltage?
Parameters used
  "boost": 3800,
  "fweak": 230,
  "fweakstrt": 300,
  "fconst": 300,
  "udcnom": 300,
  "fslipmin": 1.5,
  "fslipmax": 3,
  "fslipconstmax": 4,
  "sincosofs": 2048,
  "fmax": 500,
  "dirchrpm": 100,
  "dirmode": 1,
  "ocurlim": 1200,
  "potmin": 16,
  "potmax": 450,
  "pot2min": 16,
  "pot2max": 450,
  "potmode": 0,
  "throtramp": 5,
  "throtramprpm": 20000,
  "ampmin": 3,
  "slipstart": 50,
  "brakeregen": 0,
  "regenramp": 10,
  "regentravel": 5,
  "offthrotregen": 0,
  "cruiseregen": 0,
  "regenrampstr": 50,
  "brklightout": -50,
  "bmslimhigh": 50,
  "bmslimlow": -1,
  "udcmin": 0,
  "udcmax": 450,
  "idcmax": 650,
  "idcmin": -300,
  "idckp": 2,
  "idcflt": 9,
  "tmphsmax": 85,
  "tmpmmax": 150,
  "throtmax": 100,
  "throtmin": -100,
  "iacmax": 900,
  "chargemode": 0,
  "chargecur": 0,
  "chargekp": 80,
  "chargeki": 10,
  "chargeflt": 8,
  "chargepwmin": 0,
  "chargepwmax": 90,
  "idlespeed": -100,
  "idlethrotlim": 50,
  "idlemode": 3,
  "holdkp": -0.25,
  "speedkp": 0.25,
  "speedflt": 5,
  "cruisemode": 1,
  "udcsw": 175,
  "udcswbuck": 540,
  "tripmode": 1,
  "bootprec": 0,
  "pwmfunc": 0,
  "pwmgain": 100,
  "pwmofs": 0,
  "canspeed": 1,
  "canperiod": 1,
  "nodeid": 1,
  "fslipspnt": 0,
  "ampnom": 0
Peter
Been thanked: 9 times
Re: SDU: No udc voltage
Post by Peter »
Hi Lood. Try lowering udcsw to say 160v and see if the precharge drops out again at 5 secs. I would also be monitoring the dc readout on the parameters to see if the dc voltage rises during the 5 secs. Whats your precharge resistance value? Need that info first :-) Pete
Lood
Post by Lood »
Hi Peter,
Thanks for your reply. I will try tomorrow.
I am using a 50 ohm resistor
Peter
Post by Peter »
Ok Lood. 50 ohm is fine. I am hoping you can monitor the udc voltage before the precharge drops out. Good luck.
Peter
Post by Peter »
Also measure voltage across 50 ohm resistor during the precharge.
Lood
Post by Lood »
Changing the precharege voltage to 160V didn't make a difference. With the webinterface it is hard to measure udc at precharge. But is think it is reading udc= 1.96V all the time.
At precharge i meassure 1.93V across the resistor.
catphish
Has thanked: 99 times
Been thanked: 197 times
Post by catphish »
If you're definitely seeing 186V going into the inverter and at the same time, udc is showing near zero then one of two things must be wrong:
1) The udc measurement circuit is broken.
2) The udcgain parameter is wrong
I'm not sure if this helps you, but I can't think what else could be wrong here.
Peter
Post by Peter »
You should see the voltage change across the resistor at start of precharge and at the end as the capacitors charge up.
Should be a high voltage across it at the initial start of precharge which reasonably quickly drops to a few volts after a second or two.
As another test put a load across the inverter cables and make sure your precharge contactor/resistor etc are actually allowing current to flow.
Suggest a 100w lamp (not LED) if you can find one :-)
Lood
Post by Lood »
Thanks for te response. I don't have a 100W lamp, but I will test (this weekend) the prechare system by pulling some current via the dc/dc (Tesla GEN2) converter. I am afried that i have to remove the inverter from the car for futher testing.
Lood
Post by Lood »
The precharge circuit is providing current, so this is not the issue.
With the inverter now removed from the car, I checked:
* IGBT (diode test) test results are OK;
* A visual inspection of the driver-board seems OK;
* HVIL circuit was not working (bad contact in DC- connector), So I disconnected the HVIL on the OI board (conn 2), no result;
* I tested the OI udc-read by simulating a voltage on pin 1 of the IGBT-drive connector, and then the UDC-value was reading something, so the IO board seems OK;
* I tried to measure the UDC directly from the driver-board (pin 1), but there was no voltage.
Conclusion, the UDC measurement of the driver-board is bad?
But it seems impossible to remove the driver-board, so I guess the only option is to look for a new inverter (or drive unit)...
Has thanked: 363 times
Been thanked: 249 times
Post by jrbe »
Could be a bad solder joint at a connector. It's probably worth reflowing the connectors first.
Been thanked: 1914 times
When disconnting hvil remember to close the jumper on the oi board. Won't solve the udc issue though
Lood
Post by Lood »
I have ordered another inverter, and I hope this one will work.
What I don't understand is why at first the inverter worked (@48V), then I connected 190V, and it stopped working (the UDC-measurement).
One thing I did wrong was that I connected the gas pedal potentiometer the wrong way to the OI-board. At full throttle (no HV connected), the OI-board switched off and on again. After connecting the potentiometer correctly, the OI-board worked normally again.
Lood
Post by Lood »
The inverter arrived, it passed the diode-test. Then I tested it with a bench power supply (max 30V), UDC reading was working.
Today I installed it in the drive-unit, applied 180V and the UDC reading is not working any more. (PRECHARGE error)
So bad luck again?!
Where do I find a working SDU-inverter?
Post by jrbe »
What hasn't changed between inverters and boards? The issue likely lies there or there is some error being copied over.
Do you have verified good grounds?
Lood
Post by Lood »
First inverter:
* Test at 48V; everything is working OK; the motor is spinning.
* Test at 180V, no udc reading
Second inverter:
* Bench test of inverter at 30V power supply. UDC measurement is working.
I grounded the drive unit (via the grounding strap) to the car chassis.
What I didn't change:
* OI board (V8)
* HV-Battery, including precharge circuit
* HV-cable to drive unit
* drive unit
I did change the parameters with the precharge relay closed (HV connected via the precharge resistor). Can this be the issue?
The question for me is, did I do something wrong (twice) or did I have a bad inverter (twice)?
Why does the UDC measurement fail after supplying HV?
I think I will open 1 of the inverters, and have a look at the UDC circuit (viewtopic.php?t=2345)
Does the udc measurement come back when you drop back to 48V? What is the voltage on pin 1 (UDC_HI) at various bus voltages?
Lood wrote: Tue Dec 19, 2023 2:01 pm One thing I did wrong was that I connected the gas pedal potentiometer the wrong way to the OI-board. At full throttle (no HV connected), the OI-board switched off and on again. After connecting the potentiometer correctly, the OI-board worked normally again.
Haha, I did exactly that a long time ago. It shorts out the 5V supply. Might damage the pot but not the board.
Lood
Post by Lood »
johu wrote: Mon Jan 15, 2024 7:12 pm Does the udc measurement come back when you drop back to 48V? What is the voltage on pin 1 (UDC_HI) at various bus voltages?
No, It doesn't come back at any voltage.
Post by jrbe »
Do any of the other analog inputs work? ( Like throttle, temp, etc.)
Lood
Post by Lood »
jrbe wrote: Thu Jan 18, 2024 11:45 pm Do any of the other analog inputs work? ( Like throttle, temp, etc.)
Yes, the OI board seems to be working fine. All inputs are working, and when applying a voltage on pin 1 of the power-stage connector, I get an udc reading in the web interface.
Lood
Post by Lood »
What I don't understand is that if the inverters were already broken when I got them (so they were broken at high voltage), why did they work at first (when I tested them) at a low voltage?
When I applied a high voltage, the inverters stopped working. But after that, the inverters didn't work at low voltage anymore...
I don't understate it, so that makes me doubt that I am doing something wrong (destroying the inverters).
Post by jrbe »
Do the inverters turn the motor after this event and it's just the udc signal that's bad?
Similar threads of testing ok at low voltage then failing at operating voltage.
viewtopic.php?p=36622&hilit=Tesla+fail+ ... age#p36622
viewtopic.php?p=63286&hilit=Tesla+low+h ... age#p63286
Looks like udc floats to about 209v if it's not connected. Seems something is shorting out the signal in your setup(s).
viewtopic.php?f=10&t=3397
Lood
Post by Lood »
I got another (3th) inverter, this time with drive unit.
This one also passed the diode test, and with a bench power supply the udc reading is working.
But now I am a little afraid to hook it up to HV.
So first, I want to check if the parts I didn't change are OK:
OpenInverter Board:
I have a V8 board,
* The 3.3V circuit is at 3,297V but the 5V circuit is 4,90V. Is this a problem? (I read in some topics that it should be just over 5V?)
* The soldering looks OK by visual inspection
* The board draws approximately 250mA with nothing external connected
* version: 5.20.R-sine
* I have changed the parameters with HV attached (the positive contactor was always open, but the precharge contactor was closed)
* How do I properly turn off the inverter? First, switch off 12V to the inverter, and then switch off HV?
Drive Unit:
This has worked at 48V (first run in April), since then, nothing has changed with this unit.
But now I have a second drive unit, so maybe test this new one first.
Battery/Precharge
Tested the precharge circuit with a light bulb. It seems to work OK
I'm a bit reluctant for advise because it is so strange. The odds of two broken inverters seem low. It must be something with your setup. Maybe try bringing back HV with a super high resistor.
Lood
Post by Lood »
Removed the power-stage from the casing (like this viewtopic.php?t=2345)
You can also remove the power stage without removing the cover.
Remove the orange screws (easy) and red screws (with a thin screwdriver T20)
Remove the purple clips from the battery terminals, put a little hook in the gap, and just pull them out.
Now the capacitor is stuck in the bottom of the case. Remove the cooling covers and push the unit out of the casing with a screwdriver.
the udc measuremnet circuit is located on the bottom side of the PCB, near the C-phase cable:
It is a C87BT, circuit is like this:
Anyway, I checked all resistors on the Open Inverter board and compared the values with the BOM (V8):
there were some differences:
I assume the temperature sensor resistor values are not that important.
Can these differences cause any issues?
