Zombieverter or Lexus GS450h VCU that is the question. Topic is solved
dadiowe
Has thanked: 53 times
Been thanked: 25 times
Re: Zombieverter or Lexus GS450h VCU that is the question.
Post by dadiowe »
DkubusEV wrote: Fri Mar 31, 2023 9:21 am Very glad to learn as to why regen was removed, seems very logical, I wish I was able to do coding for such things so I could contribute to the zombie situation but unfortunately I'll need to remain patient on the sidelines. Cheers for the info.
Crasbe does your code include gear change? As I would assume it might be a while until gear change is also included in the Zombieverter software. would love to "light up" that rear end :) .
catphish
Has thanked: 99 times
Been thanked: 197 times
Post by catphish »
dadiowe wrote: Fri Mar 31, 2023 9:57 am Crasbe does your code include gear change? As I would assume it might be a while until gear change is also included in the Zombieverter software. would love to "light up" that rear end :) .
I was sure the gear change code is in Zombie. Damien used it in his recent dyno run.
dadiowe
Post by dadiowe »
I think he enabled it for the dino but is unsure about letting it out in case someone drops it into first at to high a speed and the programming does not compensate. I think it is a similar reason for regen i.e. car suddenly reversing.
catphish
Post by catphish »
dadiowe wrote: Fri Mar 31, 2023 10:11 am I think he enabled it for the dino but is unsure about letting it out in case someone drops it into first at to high a speed and the programming does not compensate. I think it is a similar reason for regen i.e. car suddenly reversing.
The functionality is there, it works, but there are two big caveats:
1) It's not currently tied to a digital input, so you can only change gear with the web interface or CAN message.
2) Nobody has successfully done at gear change on the GS450H while the vehicle is moving.
As you suggest, number two is probably the reason for number one. It needs somebody to work out how to safely do the shift while moving, probably a specific sequence that we don't yet know. Until then, it's not a particularly useful feature, but you can definitely set the gear in the web interface if you want.
et0
Has thanked: 15 times
Been thanked: 6 times
Post by et0 »
Yes, I meant we changed from Zombieverter to "old" GS450H control board. May change back if the situation changes but the Zombie had too many issues that I wasn't able to solve myself.
As far as I know neither option has automatic gear change implemented. The Catphish version uses the brake (!) input to select gear, which I guess can be from the shifter, under careful control of the driver. We do NOT use that, just staying in one gear for now. If we need auto change I believe that I can implement it.
streber
Post by streber »
FWIW I ported the GS450h throttle map code from the GS450h VCU software to the Zombieverter for use in my E46 + GS450h project.
Use at your own risk it bypasses most of the current/voltage/etc protection code but drives smoothly and has regen: https://github.com/streber42/Stm32-vcu/ ... u_throttle
DkubusEV
Has thanked: 146 times
Been thanked: 15 times
Post by DkubusEV »
streber wrote: Tue Oct 31, 2023 6:33 am FWIW I ported the GS450h throttle map code from the GS450h VCU software to the Zombieverter for use in my E46 + GS450h project.
Cheers this is awesome news, now I just need to work out how to get this into my ZombieVerter (I've not done that bit before)...
Thanks for sharing, I sincerely appreciate your efforts and everyone else that has contributed to this. Cheers.
1998 Mercedes R170 SLK gs450h project
2003 Smart-Roadster hillclimb EV (DC)zilla2k
AWD custom sports car ev6-gt based
6x6 Mercedes truck triple drive units from mg-ZS
1990 Daihatsu charade G100 3 door hyper9 .
joeflickers
Has thanked: 33 times
Been thanked: 10 times
Post by joeflickers »
Idd love to implement regen, I'm currently using Gs450h with the Zombie vcu, idd love to know if the regen code you implement on the zombie with your code works reliably, does it use Throttle to regen or the brake input?
Has thanked: 545 times
Been thanked: 153 times
Post by Jacobsmess »
joeflickers wrote: Thu Mar 14, 2024 1:37 am Idd love to implement regen, I'm currently using Gs450h with the Zombie vcu, idd love to know if the regen code you implement on the zombie with your code works reliably, does it use Throttle to regen or the brake input?
It's worth checking Damien's video on why regen isn't included in the zombie at the moment and being sure you're comfortable with it at the moment.
Has thanked: 329 times
Been thanked: 847 times
There is development ongoing to get regen implemented correctly, i am working on this at the moment.
Currently testing on various vehicles and setups to verify this works.
tom91 wrote: Thu Mar 14, 2024 9:28 am There is development ongoing to get regen implemented correctly, i am working on this at the moment.
That's exciting news. Do you know when it might be released? In weeks or months? Or not sure/willing to say?
https://github.com/damienmaguire/Stm32-vcu
Damien is going to test it now. First tests concluded with an outlander rear inverter.
joeflickers
tom91 wrote: Thu Mar 14, 2024 8:26 pm https://github.com/damienmaguire/Stm32-vcu
How is the test so far? Do we have regen success with the gs450?
joeflickers wrote: Sun Mar 17, 2024 3:35 am How is the test so far? Do we have regen success with the gs450?
I am planning to do some testing next week with a build with GS450h. Other vehicles configurations are also being tested by Damien, he will create a release once all testing is done.
Note the GS450h testing requires the removal of regen blocking in the GS450h code.
joeflickers
tom91 wrote: Sun Mar 17, 2024 10:24 am I am planning to do some testing next week with a build with GS450h. Other vehicles configurations are also being tested by Damien, he will create a release once all testing is done.
I'm using the zombie and I realised the firmware versions V2.04A and V2.05A are not running /inverter is not communicating with the zombie vcu after I upgrade and power cycle the vcu and retaining similar parameters settings, any other version below this works very well on my car (my car is Mercedees W124 with 77kwh battery back 360v). firmware is directly from Damiens GitHub with no modification in the Bin. File. Anyone running this two versions successfully?
DkubusEV
Post by DkubusEV »
joeflickers wrote: Mon Mar 18, 2024 6:22 am I'm using the zombie and I realised the firmware versions V2.04A and V2.05A are not running /inverter is not communicating with the zombie vcu after I upgrade and power cycle the vcu and retaining similar parameters settings, any other version below this works very well on my car (my car is Mercedees W124 with 77kwh battery back 360v). firmware is directly from Damiens GitHub with no modification in the Bin. File. Anyone running this two versions successfully?
Hi Joe, very interested to hear more about your w124 with gs450h running gear as I bought two gs450h packages I'm using one for the slk230 swap and was planning the other for my 1990 300ce-24 "c124" w124 conversion... do you have a build thread for your 124?? Cheers
Mike.
joeflickers
DkubusEV wrote: Mon Mar 18, 2024 7:17 am Hi Joe, very interested to hear more about your w124 with gs450h running gear as I bought two gs450h packages I'm using one for the slk230 swap and was planning the other for my 1990 300ce-24 "c124" w124 conversion... do you have a build thread for your 124?? Cheers
Mike.
unfortunately I don't have a thread on this build
Others do not have this issue, please review your settings.
joeflickers
tom91 wrote: Mon Mar 25, 2024 11:49 am Others do not have this issue, please review your settings.
thanks,i figured out that my inverter motor combo was incorrect, inverter was for the GS600H motor, now got the proper inveter and it runs
joeflickers
yesterday I loaded the new software V2.15A aiming to also test the awaited regen and gear change for the gs450h, the car moves forward with no issues but I had very little power on reverse and the car would hardly back-up, anyone that has already tested this new release and is willing to share their parameters setting or highlight changes needed, was previously running v2.05 with no issues
LRBen
Has thanked: 121 times
Been thanked: 290 times
Post by LRBen »
joeflickers wrote: Wed May 01, 2024 3:29 am yesterday I loaded the new software V2.15A aiming to also test the awaited regen and gear change for the gs450h, the car moves forward with no issues but I had very little power on reverse and the car would hardly back-up, anyone that has already tested this new release and is willing to share their parameters setting or highlight changes needed, was previously running v2.05 with no issues
There is now a throtmaxrev setting that defaults to 30. Allows you to set a lower throtmax in reverse so you don't get full power reverse.
Try increasing that.
joeflickers
LRBen wrote: Wed May 01, 2024 5:51 am There is now a throtmaxrev setting that defaults to 30. Allows you to set a lower throtmax in reverse so you don't get full power reverse.
thanks @LRBen,letme try it out
joeflickers wrote: Wed May 01, 2024 3:29 am I have issues
POST a .JSON if you want help with settings or are having troubles.
