EM57 ZE1 motor, last connector pinout question
- mnmn
- Has thanked: 17 times
- Been thanked: 3 times
Hello, I have a ZE1 Leaf stack, with complete wiring (fortunately).
The connector at the end of the signal wires looks like this: Can you please help me showing the pinout of this connector?
And where can I buy a mating connector to it?
Thank you in advance
EV-FAN
Re: EM57 ZE1 motor, last connector pinout question
I found harness and wiring diagram fo ZE1
PM with your email to sent it or better allow admin to attach a larger file (20MB)
mnmn wrote: ↑Mon Jun 05, 2023 10:39 am Hello, I have a ZE1 Leaf stack, with complete wiring (fortunately).
- mnmn
You are great, thank you!
I have just sent you a PM.
EV-FAN
Hi ginetto. Please could you PM me the diagram too.
is there a way to store this pdf in the openinverter space?
I can't attach here due to size
Hello Ginetto and Adamzki, is it possible to forward the connector pinout. It is really hard to go forward on my project because of this new connector. and send it to lesterliston at yahoo.com or ɯoɔ˙ooɥɐʎ@uoʇsᴉlɹǝʇsǝl
Thanks you so much!
Thanks you so much!
- Has thanked: 367 times
- Been thanked: 1536 times
just saw this. How large is the file?
Attachment limit raised, try uploading now
here attached you have the ZE1 Network Diagram document where available all harnesses and network
20121_nissan_leaf_Network_diagram.pdf
- Nissan Leaf ZE1 Network and Harness Diagram
- (19.57 MiB) Downloaded 372 times
- Has thanked: 212 times
- Been thanked: 173 times
I tried adding this to the wiki but it wouldn't allow it. Said file name was not allowed. It's 2021_nissan_leaf_Network_diagram.pdf
I'll check, maybe I need to enable pdf
