Nissan Leaf Gen3 Stacks
nkiernan
Has thanked: 514 times
Been thanked: 95 times
Post by nkiernan »
Picked these up from a local mechanic who's moving premises so needed to sell off some parts. I'm not that familiar with the Leaf stuff, is there a way to tell what kW these are? I'm presuming 110kW as they're 2018.
3 full stacks with the 6.6 charger, type 2 and chademo charge sockets, A/C compressor, gearbox etc. Maybe someone in Ireland thinking of a Leaf stack for their project, let me know :)
StefanFranzen
Re: Nissan Leaf Gen3 Stacks
Post by StefanFranzen »
Yes 110kW stacks, you can see on the inverter part number.
291A0-5SA0A = 110kW inverter
291A0-5SN0A = 160kW inverter
Has thanked: 360 times
Been thanked: 249 times
Post by jrbe »
Only difference found between 110kw & 160kw is the main controller in the inverter.
viewtopic.php?p=45803&hilit=160Kw+and+one+110Kw#p45803
The Open Inverter control board for a gen. 3 leaf inverter is being tested now, viewtopic.php?p=64365#p64365
Based on the info in the first link, the gen 3 OI board should allow 110kw inverters to make at least 160kw. This needs to be proven though.
nkiernan
Post by nkiernan »
Thank you both for the replies :)
Wattamidoing
Post by Wattamidoing »
Hi, how much are you looking for? Thanks
Landsi
Has thanked: 15 times
Been thanked: 7 times
Post by Landsi »
I would be interested - can you PM me the price you‘re looking for? (Can‘t yet PM myself)
Cheers
Plan to build someday soon<TM>:
VW T3 Bus
Leaf Motor Stack incl Transaxle
Brat Industries VW Driveshaft Adapters
Model 3 55kwh Battery / MEB 58kwh Battery
Foccci CCS
Zombieverter VCU
nkiernan
Post by nkiernan »
Still available :)
nkiernan
Post by nkiernan »
Still available :)
nkiernan
Re: Nissan Leaf Gen3 110kW Stacks
Post by nkiernan »
I still have two of these stacks and would be great to clear some space if anyone's interested! Based in Northern Ireland
£900 each!
nkiernan
Post by nkiernan »
Bump up!
