is300h inverter with gs450h gearbox (running)
Zechy
Has thanked: 47 times
Been thanked: 38 times
Post by Zechy »
I'm using a is300h inverter with a gs450h gearbox.
I've driven about 120km so it works. But I'm having some issues. (This is my 1st conversion so likely wiring issues :) )
I can only get 125 amps from MG2. 320V
I can't go faster than 85km/h (4000rpm) then it's like a rev limiter kicks in.
I'll start by making sure the wiring is shielded and not running over the HV cables (thanks for the advice on discord)
Has thanked: 91 times
Been thanked: 517 times
Re: is300h inverter with gs450h gearbox (running)
Anyone logged the sync serial Comms on a 300h inverter?
rstevens81
Has thanked: 29 times
Been thanked: 114 times
Post by rstevens81 »
an extra couple of thoughts have come to me...
1. Which inverter have you selected in the zombie gs450h/300h? as the code that is sent to the inverter is different.
2. Is your driveshaft locked yet?
3. there is a difference between the 300/450h transmissions in of the mg1:mg2 ratios i'm wondering if this mismatch is causing one to get dragged and hence acting like a rev limiter, (i can find the code gs450h in zombie but not the corresponding code for 300h).
Zechy
Post by Zechy »
rstevens81 wrote: Mon Dec 04, 2023 10:08 am an extra couple of thoughts have come to me...
Thanks for the excellent advice
1. I've selected the 300h inverter option in Zombieverter.
2. The driveshaft is locked
3. Oh I see. In 450h the torque request ratio is (MG1/MG2) is around (2.29/1.9). In 300h it is around (2.6/3.3) - Pretty much 5/4 vs 4/5
I'll change the code and have a go tomorrow.
rstevens81
if that doesn't work it maybe worth unlocking the driveshaft (i know a pita, but a price for development work :) ) that way we can isolate any issues to do with that, however i would wait till you get shielded cable first because otherwise you will be changing too many things at once.
Tachopis
Has thanked: 6 times
Been thanked: 14 times
Post by Tachopis »
Hi Zechy, did you have a change to test it? I'm gonna use a gs450h and not sure if I could use other inverters, from Toyota, apart of the list:
- G9200-30040
- G9200-30061
- G9200-30051
- G9200-30040
- G9200-30030
- G9200-30180
- G9200-30170
Seems the ones for Ls300h or Toyota Prius/Yaris/Auris are much more cheaper.
Zechy
Post by Zechy »
Tachopis wrote: Tue Dec 12, 2023 10:59 pm Hi Zechy, did you have a change to test it? I'm gonna use a gs450h and not sure if I could use other inverters, from Toyota, apart of the list:
- G9200-30040
- G9200-30061
- G9200-30051
- G9200-30040
- G9200-30030
- G9200-30180
- G9200-30170
Hi Tachopis
I don't have enough information yet to confirm the list. I only have a Camry and is300h inverter.
I'm trying to get G9200-30130 to work at the moment.
I've had some success with Camry G9200-33172 but not there yet.
Zechy
Post by Zechy »
I replaced the shielded resolver cables and moved them away from HV cables. This didn't have much of an effect
I did some more digging in the Camry logs from @johnspark and found code to unlocking power.
This changed the current draw on MG2 from around 125Amps to 250Amps
The issue with the speed being limited remains though. Might have something to do with the Speedsum HTM[0] but haven't figured it out.
If anybody has HTM data for a 300h that would be helpful
Tachopis
Post by Tachopis »
Zechy wrote: Sat Dec 16, 2023 3:37 pm Hi Tachopis
Great, thanks. Are you using a gs450h engine/gearbox for this test? or are you gonna try with the ls300h?
Woodfie
Has thanked: 221 times
Been thanked: 96 times
Post by Woodfie »
That looks hopeful .
On a similar mismatched smaller inverter, larger trans
As in Prius zvw30 gen 3 inverter and L210 gs300h trsns
Am capping at 85-90A and speed limit of 63kph
But when no load can get 132kph,or more
So some fiddling of HTM looks like could help.
Zechy
Post by Zechy »
Tachopis wrote: Sun Dec 17, 2023 10:34 pm Great, thanks. Are you using a gs450h engine/gearbox for this test? or are you gonna try with the ls300h?
I want to use the is300h inverter in my car.
Woodfie
Post by Woodfie »
Zechy wrote: Mon Dec 04, 2023 12:06 pm Thanks for the excellent advice
What is your differential ratio, And wheel diameter please
Also the comment 2. driveshaft is locked .....I take it this refers to the input spline , where the clutch like damper attached to the original ICE.
Zechy
Post by Zechy »
Woodfie wrote: Sat Dec 30, 2023 7:50 am What is your differential ratio, And wheel diameter please
My differential ratio is 2.93. Sorry yes. Input spline where ICE used to be is locked.
Wheels are 225/60 R15 - 651mm diameter
Zechy
Post by Zechy »
Zechy wrote: Mon Dec 04, 2023 8:09 am I'm using a is300h inverter with a gs450h gearbox.
Issue resolved. I changed the tmphs code as suggested on the BMW Z3 discussion from 16bit to 8bit: temp_inv_water=int8_t(mth_data[20]);
aaronmcg
Has thanked: 15 times
Post by aaronmcg »
Zechy wrote: Sun Feb 18, 2024 12:58 am Issue resolved. I changed the tmphs code as suggested on the BMW Z3 discussion from 16bit to 8bit: temp_inv_water=int8_t(mth_data[20]);
hi sorry to be asking a totally ignorant question. im still sourcing parts and figuring out how they connect to zombie verter;
in the zombieverter interface, are you selecting inverter as is300h and just connecting the gs450h directly to the inverter or do you have to select an option in zombie to tell it the gearbox is a gs450h?
( i have purchased an IS300h CVT gearbox and wondering what inverter i can use )
