VW ID.3 62kwh Battery Pack Teardown
Forum on Volkswagen related hardware, so VW, Audi, Seat, Skoda etc.
Has thanked: 633 times
Been thanked: 1610 times
this gentlemen does a proper 2021 VW ID.3 62kwh Battery Pack Teardown, hope you enjoy
Configuaration
  • 108 Cells
  • 450 Volts
Re: VW ID.3 62kwh Battery Pack Teardown
Testing the VW id3 battery module balance port, important to know before you buy any BMS to it.
Capacity test VW id3 id4 battery module
Open up a VW id3 id4 lithium battery module.
Been thanked: 413 times
Gregski wrote: Mon Nov 20, 2023 2:46 am Open up a VW id3 id4 lithium battery module.
Yeah... i just managed to burn some fuses in my modules. I will have to cut those modules and then figure out how to fix them in place since i will be cutting the back flange off...
After i repair the fuse i intend to glue the block back but for sure it wont be able to carry 30kg!!!
