l210
Drive motor: 1KM (105 kW / 300 nm)
Engine: A25A-FXS (135 kW / 221 nm), 2AR-FSE (131 kW / 221 nm)
Total power output: 166 kW (226 PS) (AZSH2#), 162 kW (220 PS) (AVE3#, AVC10, AWS21#, AWL10)
Applications: Crown AWS21#.AZSH2#, Lexus IS300h AVE3#, GS300h AWL10, RC300h AVC10
Features: coaxial configuration, 1-stage motor speed reduction planetary gear.
1 - motor-generator MG1, 2 - damper, 3 - mechanical oil pump, 4 - motor speed reduction planetary gear, 5 - motor-generator MG2, 6 - power split planetary gear (PSD)
1 - motor-generator MG1, 2 - input shaft, 3 - power split planetary gear (PSD), 4 - intermediate shaft, 5 - sun gear (MSR), 6 - ring gear (MSR), 7 - output shaft, 8 - planetary carrier (MSR), 9 - motor speed reduction planetary gear (MSR), 10 - pinion gear (MSR), 11 - motor-generator MG2, 12 - planetary carrier (PSD), 13 - ring gear (PSD), 14 - pinion gear (PSD), 15 - sun gear (PSD)
