I'm not sure [WIP] is the proper tag at this point, but it's the closest available. I still feel like I'm in the planning stages, but I could use a bit of help already. That's probably a sign but I'm going to willfully ignore it and push on. What I really want to build is a Tesla dual motor conversion. I've been trying to plan out a build specifically for drag and drive events for a while now, and just saw that P.S.Mangelsdorf beat me to it. Big congrats to them for finishing Drag Week this year.
I intend to pick up a ~complete-ish Model S dual motor and harvest its running gear. I wanted to run this plan by you guys, though, because I've got a few questions. What I'm thinking of doing is of course installing both motors - likely SDU in the front and LDU in the rear just because that's the original configuration, but we'll see once the hardware is all together, what fits where. I would like to try to use the Model S battery as well since I'll have it and it should be the simplest to integrate (electrically speaking), but this will largely depend on the shape and size of things. I've also considered splitting it up into a front pack and a rear pack if I can't fit it in the main floor. I'm looking at a model year 2016+ Model S because the chargers had a higher capacity. Thanks to this forum for that info. I'm in Florida, so air conditioning is also a must. That's all I really want to carry over from the Model S to the E320. Anything else is low-priority "maybe someday" projects that will never happen.
My biggest question is would this truly require an - or rather two - OpenInverter boards? I think it depends on the extent of the swap, right? If I were to put all of the Tesla control systems in, it should work because it won't "know" it's riding in an old chassis. But do we know the lower limit of what hardware is needed to run on the OE control boards? I assume the entire CAN-BUS system would need to be online, but I'm not certain. Assuming I do need OI boards, I'd also need a vehicle control unit to make them play together, correct? Something like Zombieverter, but are there any other options?
Anyways, that's just a preliminary list of questions to help ensure I plan and shop correctly. I haven't had much luck finding any info on completed dual-motor swaps. There's one shop down here in FL that's done it in a C10, but that's running on Holley controls, I believe. And I think there's one or two others that were also professional builds. What I'd really like to do is document this so it's a bit more accessible to people who know as little as I do. The intent is equal parts going fast and learning EVs because I ain' never done this before. If you made it that far, here are a couple pictures of the chassis for this conversion. It's pretty clapped, but the structure is solid and it was dirt cheap. A truly rust free CA car. It's already rustled a lot of jimmies on the Mercedes forum where I've written my intent. Apparently, according to them, if it doesn't have that MB stamp on it, it cannot possibly work.
