For the decade that I have owned the Forester, I have done a lot of wrenching so I am not unfamiliar with the mechanical aspect of vehicle modifications. I have also dabbled with Arduino boards and 3D printers so I am not a stranger to fiddle around with things to make them work. I have been following Damiens work on the Lexus/Toyota gearbox and inverters. The idea of a simplified conversion process (custom driveshaft instead of adapter plate) was really appealing. So recently, I pulled the trigger on one of the Lexus GS450h gearbox. I am forgoing the AWD and building a RWD to keep things simple.
Cost tally (in Canadian Dollars rounded up to the nearest $5):
$740 - GS450h gearbox
$100 - GS450h gearbox oil pump controller
$040 - Gear position sensor connector
$525 - GS450h inverter
Total so far: $1,405
