I tweaked regen to -60, as -100 was now way too violent and locked the tires. So I approched intersection, and just lifted accelerator .. saw regen kW value raising in my display, to somewhere around -40kW .. and all the sudden I hear click, and motor goes to neutral. I rolled to bus stop, and started wondering what happened. I hadn't hit OVERCURRENT before, but I've read that people have hit it multiple times, testing the motor.
So first, I just turned the key, waited a bit, and turned power back on for inverter. I can hear contactors click. Selected D, pushed accelerator .. but nothing happened. Did that few times.. same thing. Then went for safety switch, manually cut the HV and 12v. Waited a while, and put them back .. still the same thing. Checked my Orion BMS that if there is some error that needs to be cleared, but there was nothing. Not even a fault code. Everything on BMS side looks normal. (EDIT: it ended up being BMS opening contactors while regen)
I have set tripmode=1 (keep contactors closed / dc switch on), so even with error, contactors should not open.
From web interface, I can see lasterr = OVERCURRENT. My battery voltage is 220-300V, Tesla 5.3kWh modules. I'm running the latest stm32_sine v5.27.R. Tesla sport LDU. boost was set to 1400.
I have no idea why it triggered overcurrent. Regen was probably doing -180A back to battery (battery voltage was about 250V at that point) when it happened. My ocurlim was set to -2500. idcmax 950.
Did I actually broke the LDU, or is there anything I could do to fix this situation? Help!
