1967 vw split window bus
-originally a swing axle rear end currently being converted to a beetle irs with some custom removable brackets
Body work todo but I’m just doing the drive train
-zombieverter VCU
For testing a 16kwh gen 1 Chevy volt battery
Much like that brat, we will be doing no modification to the original chassis for fitting the electric drivetrain. Everything must be bolt on!
First off will be making a “universal” bolt in motor cradle. Adaptable to fit a variety of motors
first two drive trains to fit are:
-outlander hybrid rear drive unit
-Nissan leaf gen2 drive unit (em57)
From first measurements it’s very tight fit for the full leaf stack(gearbox, motor, inverter, pdm) without the pdm, the leaf motor/gearbox/inverter should fit great! Drive shafts are pretty simple, the leaf-to-vw conversion stubs allow the original vw axles to bolt right up to the leaf gearbox Once motor is mounted, a new oil feed system is needed, as the motor and gearbox will be running in reverse. looks like one of the fill/drain plugs could be used for an oil feed insert.
Outlander rear drive unit will be much simpler as it’s smaller and will be mounted in it original orientation.
