Have you tried to send all IDs filled with data and with different lengths with the right checksum?7yatna wrote: ↑Tue Jul 04, 2023 8:56 am i did the same thing but it looks like the control message format for my compressor is a little bit diffrent so no change in the feedback message.
i will take another try at it or i will go tesla can controlled compressor.
thank you for your help on the heater it worked as you mentioned.
VW A/C Compressor
- muehlpower
- Has thanked: 14 times
- Been thanked: 141 times
Re: VW A/C Compressor
- Has thanked: 35 times
- Been thanked: 32 times
I'm not sure what the pinout is yetmuehlpower wrote: ↑Wed Jul 05, 2023 9:18 am Have you tried to send all IDs filled with data and with different lengths with the right checksum?
What is the power output of the DBK heaters by the way? Does not say on the label.
- Has thanked: 71 times
- Been thanked: 28 times
Sorry a little of topic, but are you aware of any limitations on how this heater can be mounted? I'm looking to mount it horizontally flat.muehlpower wrote: ↑Sun Apr 18, 2021 8:06 pm I found the LIN messages for the water heater. The feedback comes on ID48. Byte 0 is power. 13 for 770W, 26 for 1540W. ID28 is sent for control. Byte 0 is power, last bit of byte 1 starts and stops.
connectors are:
HVA 280 KEY_E from TE +HV near to the body, -HV far from the body
1J0973714 1= +12V , 2= GND, 4= LIN
I so far only found good illustration of these used in audi e-tron and they're mounted like this.... As an example. Tesla battery heater has mounting orientation limitation as well described by Lars here: https://www.evcreate.com/using-tesla-th ... y%20heater
I am wondering the same. Which one is coolant input ? WHich one is coolant output? Which orientiation does it have in the car?
- Been thanked: 10 times
Hi, if this is for the HV heater i posted the answer on the correct post below
viewtopic.php?p=69292#p69292
hope that helps
