Mixing motors and inverters
Proton
Has thanked: 187 times
Been thanked: 48 times
Post by Proton »
What inverter could be used with a motor like the one in this video. they are saying that motor runs at only 70% to push the BUS.
1. What kind of inverter can power this big motor?
2 Any inverter can run any AC / 3 faze motor?
EV_Builder
Re: Mixing motors and inverters
Post by EV_Builder »
Depending on motor specification obviously the drive/inverter needs Tobe matched. There is no "one size" fits all drive.
Proton
Post by Proton »
Agree, but what kind of inverter can drive that motor. I mean a Prius inverter will not be able to drive that kind of motor. 2-3 of them ?
I do not want to do a small car conversion and I am doing the Van right now just because I have it, is cheap and I am learning.
What I am looking for really is something that can drive a RV or big buss.
Found a new method to swap the board :D
EV_Builder
Well what type of motor is it and what type of position feedback it's got? What type of power and nominal voltage?
Now your search can start. :)
New sensors are available to ehh.
Proton
Post by Proton »
Thats the thing, I paused the video but was not able to get the motor info and they do not give any details in the video.
They are saying 483HP. Looks like 6 cables go in. so 2 inverters?
I am just asking since I do not understand yet exactly how this motor inverter pairing works.
royhen99
Has thanked: 22 times
Been thanked: 133 times
Post by royhen99 »
A quick image search suggests it is propably a Siemens 1DB2024 – WS36. 6 ph requiring dual inverter
Proton
Post by Proton »
royhen99 wrote: Sun Jun 04, 2023 6:17 pm A quick image search suggests it is propably a Siemens 1DB2024 – WS36. 6 ph requiring dual inverter
thank you.
This is 750V probably more complicated setup for the batteries.
https://silo.tips/download/drive-motor-1pv5135-4ws18
So this motor has at 3500 RPM max speed.
to reach 90MPH the gear ratio needs to be arround 3.3:1
https://purperformance.com/p-29669-rpm-calculator.html
