Honda ima and his abilities An old beetle
- Romale
- Has thanked: 327 times
- Been thanked: 92 times
Hello, people!
I remember there were attempts to work with small IMA inverters more than once, and someone considered them untenable.
I will show in this topic what this wonderful little controller + v3 board is really capable of!
So, the first: a motorcycle made of beetle, 72 volts.
Second: a car weighing 1.4 tons, 140 volts.
evil neodymium
- Romale
Re: Honda ima and his abilities An old beetle
Later, I will add something else that will travel on this controller. If you are interested in the settings, feel free to ask.
evil neodymium
- marcexec
- Has thanked: 888 times
- Been thanked: 91 times
Cool, what amp limits are you running?
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
- Romale
il1gain 4,09
il2gain 4,09
overcurrent 500
idcmax 300
evil neodymium
- Romale
there is only one wiring for connecting current sensors (they receive power from the native board of the inverter), and only two wires for each power module to control the PWM relative to the total GND, + two wiring for 12 volts of the native board. this is enough for high-quality operation of the inverter.
I also make an external Wi-Fi module using a sealed type-c connector for this, and I completely fill the inverters with a special compound, which makes them protected from immersion in puddles))
evil neodymium
Ryclanmoto
- Has thanked: 4 times
- Been thanked: 3 times
Good afternoon, could you tell me where what is connected to the Honda inverter, where is which wire? thank you in advance
- Romale
Ryclanmoto wrote: ↑Sat May 20, 2023 1:59 am Good afternoon, could you tell me where what is connected to the Honda inverter, where is which wire? thank you in advance
with this connection, pinswap=4 (pwmout13)
il gain = 4.1
evil neodymium
Ryclanmoto
thanks, but don't know how to connect exactly honda insight,fit , how to connect their inverter, you have whatsapp
- Romale
so the honda fit has another inverter. it does not contain logic and it needs to immediately send control signals to its native nest. he also has external current sensors, not very convenient.Ryclanmoto wrote: ↑Sat May 20, 2023 11:33 am thanks, but don't know how to connect exactly honda insight,fit , how to connect their inverter, you have whatsapp
evil neodymium
- Romale
I have an inverter from fit. I haven't dealt with it yet. later I will make it workable and add information here
evil neodymium
- Romale
in the same topic, an inverter from honda civic
evil neodymium
Ryclanmoto
cool, we are waiting for the article, I think a lot of people would be interested in the fit inverter and insight
- Romale
update!
I tested an ima inverter from 250 volts and it didn't burn out, up to 250 amps of battery current!
this is a great power for such a small inverter!!
evil neodymium
700км пробег работает как часы. Пока без температуры инвертора и вольтметра , но это скоро решим , пока лень морочатся))
Этот инвертор неудобен в переделке. Не вижу смысла с ним заморачиваться.
Ryclanmoto
Why did you decide so, I think many will be interested in the inverter honda insight, fit Due to its compactness and cheapness, and the connection is easy through the connector chip
)))) хотелось бы на это посмотреть… Коль это так легко )))Ryclanmoto wrote: ↑Sat Jul 08, 2023 9:37 am Why did you decide so, I think many will be interested in the inverter honda insight, fit Due to its compactness and cheapness, and the connection is easy through the connector chip
Ryclanmoto
Everything has its time, at least managed to move in the project with the help of arduine, twist
- Has thanked: 455 times
- Been thanked: 1771 times
Can you pipe everything through a translator to English please.
- Romale
250 volts (60s li-ion battery). 40+ kW of power! the car is 1500 kg! 130 km / h.
as a motor, a generator with a Nissan Serena. as a ima inverter.
evil neodymium
Very nice
Why does it have 2 fuel gauges? Why did you need to pull over on the highway? Are you running in field weakening?
- Romale
no, I did not use field attenuation.
two devices are one fuel level, and the second is an economizer (the device is connected to the vacuum on the intake manifold of the internal combustion engine and shows how economically you drive)
evil neodymium
- Romale
I stopped to shift the gear to a lower gear and test the maximum speed in this gear.
evil neodymium
Thank you
I thought something went wrong because of the noises.
