Help: The motor shakes, but does not turn! There is a lot of current!
tt1012
Post by tt1012 »
If I have any more questions!
I will come to the forum for consultation!
Thank you all!
params (1).json
(1.46 KiB) Downloaded 119 times
Mhs
Has thanked: 311 times
Been thanked: 13 times
Re: Help: The motor shakes, but does not turn! There is a lot of current!
Post by Mhs »
I by no means an expert, however I suggest you to provide more details on your setup (motor and inverter details) to allow others to help you
Zombieverter
Has thanked: 91 times
Been thanked: 517 times
Are you sure your motor phase wires are the correct order?
tt1012
Post by tt1012 »
I have already solved this problem!
thank you!
But now I realize that my current sensor is not working! The voltage is normal!
1.6v。 But there has been no change in the data of il1 and il2!
And after I refueled, he remained in idle mode!
I can't control any speed!
tt1012
Post by tt1012 »
Bigpie wrote: Tue May 09, 2023 10:19 am Are you sure your motor phase wires are the correct order?
yes!
Please don't delete your original question as then it's less helpful for others and also report back how you solved the problem
